pc doesn't recognize the SD disk problems
This is a discussion on pc doesn't recognize the SD disk problems within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I've connected my backflip to several PC's with XP & Vista with no problems. But when I connect it to me laptop running Windows Vista, ...
Thread: pc doesn't recognize the SD disk problems
    Junior Member nelsonklan's Avatar
    But when I connect it to me laptop running Windows Vista, my laptop doesn't recognize the SD disk in the phone.
    I've tried different SD disks with the same problems. I've uninstalled all my Motorola phone tools and my windows sync. Still not working.
    I keep getting the message to insert the disk.
    Is anybody else having this problem?
    Does anybody have any ideas what to do?
    nelsonklan@yahoo.com
    Does the SD card that fails when in your phone work with this computer when connected some other way (card reader for instance)?
    Have you tried copying anything you need from the card and then formatting it while in the phone?
    Settings->SD card & storage
    Then press:
    Unmount SD card
    Then you can press:
    Format SD card (it is grayed out until you unmount the card)
backflip doesnt recognize update
backflip wont recognize sd card contact
