Reduce microphone sensitivity?
This is a discussion on Reduce microphone sensitivity? within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Another downside is that it turns off the "click" when an icon is pressed. Hmm, after I cycled it off and on a couple of ...
Results 11 to 14 of 14
Thread: Reduce microphone sensitivity?
    Junior Member berniesteven's Avatar
    Florida
    Another downside is that it turns off the "click" when an icon is pressed. Hmm, after I cycled it off and on a couple of times, I now have the touchscreen sounds back. I'm happy!!
    Junior Member flhthemi's Avatar
    Be nice to have a widget On/Off HAC....
    Member gwalborn's Avatar
    It would be even nicer to have an app to reduce mic sensitivity WITHOUT invoking HAC!
    gwalborn
    Senior Member jmgib's Avatar
    Kentucky
    You may could create a shortcut using AnyCUT.
adjust microphone sensitivity android
android microphone lessen
android turn down mic sensitivity
droid razr decrease mic sensitivity
how to adjust microphone sensitivity android
how to change mic sensitivity on phone
how to lower mic sensitivity skype kindle fire
how to reduce mic sensitivity in mobile
how to reduce mic sensitivity on skype
how to turn down my kindles mic sensitivity
reduce mic sensitivity android
reduce microphone sensitivity
reduce microphone sensitivity android
reduce sensitivity on google now
turn down microphone on android
