Horrible phone lag
This is a discussion on Horrible phone lag within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; ok.. heres a update.. i removed my sd card and did a factory reset.. it made a huge difference .. the txt app doesn't give ...
Results 11 to 16 of 16
Thread: Horrible phone lag
    Junior Member blown89gg's Avatar
    ok.. heres a update.. i removed my sd card and did a factory reset.. it made a huge difference .. the txt app doesn't give me an error and time out anymore... im going to give it a few days but the phone is faster than the day i got it!
    Senior Member NaplesBill's Avatar
    Quote Originally Posted by blown89gg View Post
    I think maybe now is the time to get a class 6 SD card.
    class 6? you just mean a better one?
    Class 6 is the fastest transfer rate for an SD card. If you root the phone and want to run apps off the SD card, the class 6 will make a huge difference in performance. Most store bought SD cards are class 2. Some are now coming in class 4. I was lucky enough to find an 8gb class 6 at CompUSA (they still have retail stores in FL) for $20.
    Junior Member burnsboy1's Avatar
    fix at least the one that worked for me
    Simple....delete all your conversations. Right there lag gone I love this phone again. Its not like the iphone lol
    Member sal2708's Avatar
    i had this same problem, like when i would open my phone to a text id probably had to wait about 10 seconds before i could even text, my problem: it was an app i installed that gave my phone the horrible lag. idk which one since i uninstalled the last 3 apps so yeah, but know i am up and running fast.
android forums phone lagging
at&t motorola backflip lag
do motorola phones lag
how to remove lag on phone
lag killer for phone
phone lag
phone lag?
phone lagging out
phone lags killer
reduce lag motorola backflip
reduce lag on phone
reduce phone's lagging
what is phone lag
why does motorola backflip lag
why phone lagginf
