Will NOT power on
This is a discussion on Will NOT power on within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I was in the middle of waiting for an app to load and accidentally hit the OFF button. Now it won't power on. I've made ...
Thread: Will NOT power on
    Junior Member bobbikey's Avatar
    Will NOT power on
    I was in the middle of waiting for an app to load and accidentally hit the OFF button. Now it won't power on. I've made sure it was fully charged & did a battery reseat. Nothing. It just sits at the white 'Motorola Blur' screen with the word 'Blur' flashing.
    Member Spoonman's Avatar
    Have you tried a battery pull?
    Turn it on and at the splash pull the battery for a min or two then repower it. (Dunno if that works for android phones but most other phones will drop any temp start up stuff)
    Could also try letting it sit on the splash and checking your blur account to see if it will locate you phone. If so do a remote wipe and reset the phone
how to turn on a motorola blur
how to turn on motorola blur
motorola backflip wont turn on
motorola blur is not turning on
motorola blur not turning on
motorola blur phone won't turn on
motorola blur will not turn on
motorola blur won't turn on
motorola blur wont power on
motorola blur wont turn on
my motorola blur wont power on
my motorola blur wont turn on
my motorola blur wont turn on and is fully charged
my motorola blur wont turn on\
why wont my motorola blur turn on
