WiFi bug
This is a discussion on WiFi bug within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; It's not a bug. Most cell phones don't support wireless N. If you set your router to put out both G and N it'll connect ...
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: WiFi bug
  1. #21
    Junior Member gutafaerie's Avatar
    It's not a bug. Most cell phones don't support wireless N. If you set your router to put out both G and N it'll connect fine but it may slow the router down.
  2. #22
    Senior Member jmgib's Avatar
    Kentucky
    If he is able to connect to the wireless router, it's not an 802.11n connectivity issue. He only loses access to his Exchange sync. Or at least that's what his post says.
  3. #23
    Junior Member Agentile1990's Avatar
    Nashville and Palm Beach Gardens
    That is good to know gutafaerie, but jmgib is right. Wifi still works; it is just the corporate sync app that looses connectivity.
  4. #24
    Member krowwf's Avatar
    michigan
    Boy, this 13.37 update has REALLY improved my WiFi connection! Every time I turn on the phone it's already connected to WiFi! Before it was always doing it's "trying to connect, disconnected, trying to connect" for 5 minutes before it could connect. And the touch screen seems much more responsive too. I just might forget about my iPhone 3G, if I could get a decent SKYPE app. FRING for the video calls isn't very good either. (Very choppy).
  1. Details Emerge about the Android Asus Eee Pad
    Last Post: 01-03-2011, 04:53 PM
android wifi bug
how to get samsung gem to stay connected to wifi
motorola backflip wont connect wifi
my motorola backflip won't connect to wifi
samsung 300e4a wireless connection problems
samsung captivate drops wifi
samsung captivate drops wireless problem
samsung captivate wifi wont stay connected
samsung captivate will not connect to wifi
samsung captivate won't connect to wifi
samsung captivate wont stay connected wifi
samsung gem wifi bug
samsung infuse won't connect to wifi
samsung infuse wont stay connected to wifi
wifi bug
