Screen Orientation Issues
This is a discussion on Screen Orientation Issues within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Originally Posted by krowwf when I take a video and play it back the screen turns sideways. I then turn the phone sideways and the ...
Results 11 to 14 of 14
Thread: Screen Orientation Issues
    Senior Member montREALady's Avatar
    Quote Originally Posted by krowwf View Post
    when I take a video and play it back the screen turns sideways. I then turn the phone sideways and the screen turns again. So at this point the phone is totally upside down. "???"
    I have actually never done video on the phone, I should probably try that out.
    Member krowwf's Avatar
    michigan
    I figured out you have to hold the phone sideways to take video. When taking photos you can hold it either way, so I just assumed.........LOL
    Junior Member geekman's Avatar
    you know whats weird is that the last week i had the problem with the screen not rotating it just happend all the sudden (and i know for a fact my home screen would change orientation with the phone cause its been doing it for at least 3 months till last week.
    as stated by everyone the phone will only rotate on apps and when the keyboard is flipped open
    but i dont see how some of you can say that the original intent of the home screen was to always be portrait (unless mine was messed up)
    the dialer, menu, and contact buttons would even move over to the right side of the screen so i say its a serious bug.
    also i find the video function to be annoying as well i have taken a large video only to find out that the whole shot was side ways (they should fix this)
    today my phone crashed (see restoring phone) <_< O_O >_>
    it might be related has this happend to anyone after they noticed this happen
  1. Radio Shack selling the HTC EVO Shift Early
    By danDroid in forum HTC EVO Shift
    Last Post: 01-05-2011, 11:28 AM
captivate screen wont rotate
galaxy captivate display rotation problem
galaxy s2 home screen sideways
galaxy s2 screen wont rotate
galaxy s2 wont turn sideways
google android search screen turns sideways samsung s2
my samsung captivate slide wont turn and screen rotate is on
my samsung galaxy home screen is sideways
orientation on android wont.turn
orientation problem in s2
samsung captivate home screen sideways
samsung captivate screen will not rotate
samsung captivate screen wont rotate
samsung galaxy s2 phone screen turning sideways
samsung galaxy s2 rotate screen sideways and not back
