Screen Orientation Issues
This is a discussion on Screen Orientation Issues within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Too often am I turning the phone in a new direction and the screen is staying in the previous one. Other times it would turn ...
Results 1 to 10 of 14
Thread: Screen Orientation Issues
    Senior Member montREALady's Avatar
    Too often am I turning the phone in a new direction and the screen is staying in the previous one. Other times it would turn right away (with a slighhhhht delay). It seems to be temperamental. Anyone else having this prob?
    Junior Member azbackflip's Avatar
    yes I am also having the same problem the first two days I had the phone there were no issues with the screen orientation and suddenly since yesterday it is not rotating even with the option checked unless I open the keyboard then the screen will switch. pulled battery multiple times and it doesnt fix it
    Senior Member batmania15's Avatar
    MA
    Just to let you guys know the home screen WILL NOT ROTATE when the phone is closed. The option you are checking in settings is APP specific. So MOST apps will rotate when the phone is folded but NOT the homescreen.
    Hope that helps.
    I have 9 lockerz invites if interested PM me.
    that does help. for some reason I could have sworn it had rotated before with it closed, but maybe I was imaging it, lol. thx!
    Senior Member NaplesBill's Avatar
    I personally am glad that it stays portrait when the phone is closed. I find it aggravating when the home screen rotates at a slight turn of the phone.
    The only time the home screen rotates with the standard home app is when the keyboard is open. The home screen does not rotate when you turn the phone to landscape, unless you open the keyboard.
    Most other replacement home apps (dxTop, PandaHome, Open Home) DO rotate the home screen (if you turn on that setting).
    Quote Originally Posted by batmania15 View Post
    Hope that helps.
    Yes, I know the home screen won't...unless you open the keyboard. Thanks!
    It would happen to me when I was trying to reply to a text or FB message. Not until I open the keyboard would it rotate.
    Member vasekvi's Avatar
    I hope everyone knows that beside as it was mentioned that the screen will not rotate with the keyboard open, that you have to go to Settings>Display & Security and make sure that Orientation is checked for the screen to rotate with the accelerometer.
    I noticed that some apps were written to not rotate at all, and only run in portrait mode, regardless of how the phone is held or if the keyboard is open or not.
    Quote Originally Posted by vasekvi View Post
    Yes I realize this...my screen would do it sometimes and not at another time, that's my issue.
    Member krowwf's Avatar
    michigan
    when I take a video and play it back the screen turns sideways. I then turn the phone sideways and the screen turns again. So at this point the phone is totally upside down. "???"
  1. Radio Shack selling the HTC EVO Shift Early
    By danDroid in forum HTC EVO Shift
    Last Post: 01-05-2011, 11:28 AM
captivate screen wont rotate
galaxy captivate display rotation problem
galaxy s2 home screen sideways
galaxy s2 screen wont rotate
galaxy s2 wont turn sideways
google android search screen turns sideways samsung s2
my samsung captivate slide wont turn and screen rotate is on
my samsung galaxy home screen is sideways
orientation on android wont.turn
orientation problem in s2
samsung captivate home screen sideways
samsung captivate screen will not rotate
samsung captivate screen wont rotate
samsung galaxy s2 phone screen turning sideways
samsung galaxy s2 rotate screen sideways and not back
