how to reset backflip
This is a discussion on how to reset backflip within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; My backflip is lagging when I text, does anyone know how to perform a reset? Thank you....
Thread: how to reset backflip
    Junior Member deepsouthballa's Avatar
    Moderator SSeymour's Avatar
    Hard rest or soft reset? There is no soft reset option in android you will have to power off and back on as for a hard reset there is a post on how to perform a factory reset on this forum
    deleted by author
    Can anyone talk me through the reset process?
    Whats there to talk you through? I dont mean to be rude but its just a few clicks and when you start the phone back up it will ask for the motoblur log in. Log in and then reinstall your apps and so forth.
  1. What Rumored Android Phone are you most excited about?
    By danDroid in forum Android Forum
    Last Post: 01-21-2011, 09:40 AM
  2. HTC Thunderbolt Surfaces Again!
    Last Post: 01-05-2011, 07:48 AM
  3. Screen Problem, anyone else have a "rattling" screen?
    Last Post: 11-30-2010, 04:41 PM
forgot password motorola backflip
hard reset motorola backflip
how do you factory reset a motorola backflip
how to factory reset motorola backflip
how to reset a black flip at&t phone?
how to reset a motorola backflip
how to reset backflip motorola
how to reset motorola backflip
motorola backflip factory reset
motorola backflip password reset errors
motorola backflip reset
motorola backflip soft reset
reset backflip
soft reset motorola backflip
