Sound Issues
This is a discussion on Sound Issues within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I just got my Backflip today, and up until a couple hours ago I had no complaints. I downloaded a few apps from the market, ...
Results 1 to 9 of 9
Thread: Sound Issues
    Junior Member CopeWB's Avatar
    Sound Issues
    I downloaded a few apps from the market, one of which was the Mabilo Ringtones. After installing a few new ringtones, I have realized that I can not hear them. I have checked my media volume and ringer volume, they are at max. Thoughts/comments?
    Moderator SSeymour's Avatar
    check to see if you have it set to ring or just vibrate?
    Ring and Vibrate.
    deleted by author
    Junior Member polychoron's Avatar
    re: media sounds issues
    I'm having the same problem: my media volume recently stopped working about 75%. Apps that used to sound very loud now are very quiet, too quiet. I got the volume control app and all levels are maxed, but issue remains. I read elsewhere that a complete factory reset resolved issues with media volume, but I don't want to do that. Seems like this must be software related. Is there any way to confirm which apps use the sound system?
    I uninstalled all market apps that use sound (soundboard, synthpads, games, etc), then rebooted and my media volume now works perfectly. I've resinstalled all of those app and still dont have any problems...
    Junior Member msmarvel's Avatar
    on the beach
    i got this phone before Mother's day and this past friday my speaker (media volume) went out. I called ATT they 3-wayed us to Motorola-they transferred us to the Android Dept. they then suggested I take it back into where I purchased my phone.. ( I did everything I could think of--went to quick settings/sound manager in the app department nothing changed.) I un-installed EVERY app and nothing worked. IDK what it is cuz before my sound worked fine-- maybe a defect? hope it gets fixed
    deleted by author
    Junior Member Craig_attdroids's Avatar
    Oregon
    I too have had the sound issue. It seemed to start right after I downloaded some free ring tones. After removing all the ring tones and doing a factory reset my sound came back. I can't be sure that it was the free ring tones, but I think I'll stay away from them.
  1. Galaxy s power pack...
    Last Post: 10-28-2010, 12:08 PM
  2. Samsung Epic 4g coming August 11th?
    Last Post: 08-05-2010, 03:09 PM
media volume not working on atnt motorola blur
motorola backflip media volume low at max volumw
motorola backflip sound issues
motorola backflip sound stop working
motorola backflip speaker not working
motorola blur media volume
motorola flipside loudspeaker
motorola flipside not ringing
motorola flipside speaker
motorola flipside speaker not working
motorola flipside will not ring
motorola flipside won't ring
my motorola backflip media volume is low
my speaker is low with media on my backflip
why is my motorola backflip volume so low
