Need Help Charging Phone
This is a discussion on Need Help Charging Phone within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Hello, my phone wont charge when I plug it into an outlet. I have tried many different outlets in my house and the phone will ...
Thread: Need Help Charging Phone
    Junior Member swimmerchick5891's Avatar
    Hello,
    my phone wont charge when I plug it into an outlet. I have tried many different outlets in my house and the phone will only charge when connected to the computer. how can I fix this?
    Senior Member Lendal's Avatar
    Quote Originally Posted by swimmerchick5891 View Post
    Hello,
    I don't think you can fix that. I think you need to take the charger back to the AT&T store and exchange it for one that works. Do it before your 30 days is up.
    Good luck with that.
    Yeah I am gonna see if I can get it to work and then I'll do that.
    The green light flashs and all that but the home screen says "plug in charger".
    Well, yes, but that's just it. There isn't really anything you can work with here.
    You plug one end of the cable into the phone. The other end into the little charger thing and plug the charger into the wall.
    Then, it either works or it's broken. There isn't really anything you can mess with.
  1. Acer announces Iconia Tab A500 - 10" Tablet with LTE
    Last Post: 01-05-2011, 11:54 AM
  2. Text (SMS) Message Drafts
    Last Post: 10-19-2010, 01:18 PM
motorola backflip charge
my motorola backflip wont charge
why wont my backflip charge
