Bluetooth headset connectivity issues
This is a discussion on Bluetooth headset connectivity issues within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Have had big issue with the connection dropping between my rocketfish headset and backflip. Even with the recent update it continues. BUT, I found a ...
Thread: Bluetooth headset connectivity issues
    Junior Member wilkinte's Avatar
    Have had big issue with the connection dropping between my rocketfish headset and backflip. Even with the recent update it continues. BUT, I found a simple solution if this plagues you too. When the headset drops, just select speaker from the phone screen, of course your conversation goes to speaker. Then toggle speaker off and the bluetooth picks it back up.
    Wish it didn't drop, but this is a quick way to recover.
    Junior Member Agentile1990's Avatar
    Nashville and Palm Beach Gardens
    I don't have a solution, but rather the inverse to your problem. I have a Motorola Bluetooth handsfree unit (clips to my visor). Originally I used the bluetooth switch to toggle on and off. One day I shut off the unit before disabling bluetooth and in order for me to not be connected to the unit I had to reboot the phone. Dumped the switch app and got quick settings. Worked better for some time and now it did it again.
    When ever I would adjust the volume on the phone using the side buttons it would say "bluetooth in-call volume"
    My work around= sit in my car, turn bluetooth off on the phone, wait 10 seconds, turn off the handsfree.
    BTW, turning on is never an issue.
  1. Samsung Infuse Pictures
    By danDroid in forum Samsung Infuse 4G
    Last Post: 02-23-2011, 09:10 AM
  2. Replies: 0
    Last Post: 11-22-2010, 04:54 PM
  3. Insurance for the Epic 4G?
    Last Post: 10-19-2010, 09:51 PM
  4. Blackberry Enterprise Server
    Last Post: 08-28-2010, 06:13 PM
android bluetooth headset connection
android tablet bluetooth headset issues
droid 2 bluetooth headset signal drop
motorola bluetooth headset connection issues
rocketfish bluetooth headphones, connectivity problems
