problem viewing photos
This is a discussion on problem viewing photos within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Recently upgraded to a. 16gb microsd am starting to have problems with pictures I take with the phone. When I take a picture I can ...
Thread: problem viewing photos
    Member jdsatyr's Avatar
    Recently upgraded to a. 16gb microsd am starting to have problems with pictures I take with the phone. When I take a picture I can view it for a few minutes, but after a while it shows up as an icon and does not open the picture. Older pics and imported pics open fine.some of those that open were taken with the phone in its current configuration. I replaced the phone for an unrelated mioc problem, hoping that would also fix this problem, but it did not and the problem was not affected by. Apps as it happened even with the new phone before I dl'd any apps for it. Any suggestions?
    Senior Member jmgib's Avatar
    Kentucky
    Could possibly be the SD card. I'd try to back everything up to a PC and try reformatting the card. Also, are you able to view the pictures on a PC?
    San Jose, CA
    Did you format the SD card while it was in the phone? That usually resolves these sort of issues.
android trouble veiwing pivtures
backflip micro sd issue
motorola bugs pictures
motorola razr picture viewing problems
picture problems motorola backflip
problem taking pictures motorola backflip
problems viewing pictures on android tablet
viewing photos on motorola flip phone
