WiFi Connect Issue
This is a discussion on WiFi Connect Issue within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I have been searching the web the past few days for help with the issue i have. It appears to be a known android issue, ...
Thread: WiFi Connect Issue
    Junior Member sraitter's Avatar
    WiFi Connect Issue
    I have been searching the web the past few days for help with the issue i have. It appears to be a known android issue, but here is my problem. I have WiFi access at work and at home and prefer to be connected to WiFi, however the past few days the phone will connect to the network but does not have a data connection (Browsers/Apps do not have internet connection). I check the ip on the phone and router and both are showing the ip being issued to the Backflip. The only solution I've found is to do a battery pull or a full reboot on the phone. Really frustrating!!! I've tried the free WiFi programs on the marketplace but have had no luck. Please help?
    Senior Member jmgib's Avatar
    Kentucky
    What exactly is happening? If you disable the WiFi on the phone and re-enable it, does it work?
    Yes I have done that. Turning the WiFi off and then back on, when I turn the Backflip back on it shows the connection and in the advanced WiFi options it shows an ip, however data does not work on the phone. Cannot access a webpage, apps that use data do not work, marketplace will not load, email will not come in ... etc. Thanks for quick reply
    San Jose, CA
    So this occurs for any wifi network? What kind of wireless security is on the networks you connect to? I've never had a connection issue like this, but I've only connected to networks with WEP, so maybe WPA or WPA2 is causing your problem? Just a thought.
    No only two different router I am connecting to both with WEP security keys. They are different types of routers as well. One is a linksys the other is a sonicwall. Been using the device with limited issues for over a month. This is a new problem that just came up recently. Even after a battery pull the wifi will work when "it wants to".
  1. Better app than Say My Name
    Last Post: 09-16-2010, 04:10 PM
  2. Countdown!!!!!
    Last Post: 08-23-2010, 11:08 PM
android cannot access internet after connected wifi
android what is wifi connect
backflip wifi issues
fire phone wifi connect issue
how to connect my motorola backflip to wifi
how to turn backflip on router wifi
motorola backflip wpa2 wifi not working
s4 connect to wifi but cannot access to internet
wifi for motorola backflip does not work
