Screen won't turn on after standby.
This is a discussion on Screen won't turn on after standby. within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; So this just started today... When I put my phone into standby mode and take it back out everything comes back on except for the ...
Thread: Screen won't turn on after standby.
    Junior Member zero0darkness's Avatar
    Exclamation Screen won't turn on after standby.
    When I put my phone into standby mode and take it back out everything comes back on except for the screen. I can even use the touch portion of the screen, the image just doesn't come on. Backlight, buttons, everything works just fine, there is just no images.
    At first I couldn't get it to work at all. now I have it sitting out and i can get it to work as long as i wait more than 10 seconds after putting it into standby.
    This is very annoying because if I put the phone into standby and get a call, I have to guess where the buttons to answer are otherwise I can't answer the call.
    I haven't installed anything recently either.
    Anyone know a way to fix my problem?
    P.S. if I end up having to do a factory reset, is there any way to save my contacts and settings or do I have to do it manually (i.e. writing everything down to enter again afterwards).
    So the factory reset didn't work... Making me think its a hardware problem....
    Any ideas or help would still be appreciated though
    Senior Member jmgib's Avatar
    Kentucky
    If the factory reset didn't resolve it (and you didn't reinstall any apps after resetting the phone) then I would probably have it checked out.
    I had to get a new phone, it was a hardware problem of some kind.
  1. HTC Inspire 4G heading to AT&T with new Sense UI
    By danDroid in forum HTC Inspire 4G
    Last Post: 01-05-2011, 02:52 PM
  2. Streaming Bluetooth Audio
    Last Post: 12-14-2010, 10:28 PM
ace 2 x phone wont turn on after standby mode
andriod forums desire screen wont turn after standbay
android phone won't come out of sleep mode
android phone wont come out of standby
android screen doesnt switch on after sleep
android screen won't turn on after sleep
android screen wont turn on after standby
computer monitor doens't turn on after standby
computer screen doesn't turn on after sleep
monitor doesnt turn on after standby
motorola backflip doesn't turn on
motorola won't come out of standby
my monitor doesnt turn on after standby
screen won't turn on after sleep mode android
screen wont turn on after sleep mode droid 4
