Disabling Data Roaming - possible issue
This is a discussion on Disabling Data Roaming - possible issue within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I had data roaming disabled (I am pretty darn sure). I crossed the border to the US, and low and behold I incurred data roaming ...
Thread: Disabling Data Roaming - possible issue
    Junior Member tomtom's Avatar
    I had data roaming disabled (I am pretty darn sure). I crossed the border to the US, and low and behold I incurred data roaming for the dates I was there. Furthermore, I never once saw the 3G icon during my visit.
    Has anyone experienced a similar problem, or did I just screw up? Anyways - to be sure, next time I leave the country I will change the APN!
    Senior Member jmgib's Avatar
    Kentucky
    Having data roaming disabled I believe should have prevented you from incurring data roaming charges. I haven't traveled out of the country with my phone so I can't say for sure.
  1. Countdown!!!!!
    Last Post: 08-23-2010, 11:08 PM
  2. august 11th!!!!! pre-order
    Last Post: 08-08-2010, 11:30 PM
android bug data leakage data roaming
how do i turn off the roaming on my i1
how to set the motorola i1 to roam
how to turn off data on motorola i1
how to turn off roaming on a motorola i1
i1 motorola roaming
motorola i1 disable data
motorola i1 disable data roaming
motorola i1 how to enable data
motorola i1 roaming
no romming i1 motorola
roaming motorola i1
