How to turn on vibration notification for AIM?
This is a discussion on How to turn on vibration notification for AIM? within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Hi I was wondering if anyone knew whether or not it is possible to turn on vibrating notifications for AIM? As of now, the only ...
Thread: How to turn on vibration notification for AIM?
    Junior Member facepalm24's Avatar
    Hi I was wondering if anyone knew whether or not it is possible to turn on vibrating notifications for AIM? As of now, the only notification I get is on the notification bar on the top of the screen, so I have to open my phone everytime to check for new im's. So is it possible to have your phone vibrate everytime you receive a new message? If so, how? Thanks!
    Senior Member jmgib's Avatar
    Kentucky
    Looking at the AIM app it looks like the only notification options it has are for sound/ringtone notifications. I don't see an option to vibrate the phone.
    Thanks, but even so, where do you go to turn on those options?
    Kentucky
    After signing in, go to settings and then sounds and notifications.
    That's where I found the vibration notification. Thanks a bunch!
  1. HTC Inspire 4G heading to AT&T with new Sense UI
    By danDroid in forum HTC Inspire 4G
    Last Post: 01-05-2011, 02:52 PM
  2. Streaming Bluetooth Audio
    Last Post: 12-14-2010, 10:28 PM
aim app iphone turn off vibrate
aim vibrations on iphone
android turn off vibrate notification
get aim app to stop vibrating when i get a message
how can i turn on the notification for aim
how to make aim app stop vibrating
how to make aim vibrate phone android
how to stop vibrate notifications for aim iphone app
how to turn off vibtration on aim for iphone
stop aim from vibrating iphone
stop aim vibration note
turn off aim mobile vibrate
turn off vibrate aim app
turn off vibrate aim iphone
vibration on aim on ipone
