I Need Some Help With This!!!!
This is a discussion on I Need Some Help With This!!!! within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Originally Posted by Con5150 So any app I paid for I would have to buy again...the MLB app is $15? No.. Once you log back ...
Results 11 to 20 of 23
Thread: I Need Some Help With This!!!!
    Quote Originally Posted by Con5150 View Post
    No.. Once you log back into your phone and google, it will bring up all your paid applications in the market.
    Junior Member tbutterw's Avatar
    Toronto, Canada
    I believe when you buy apps you do it through Google checkout, so as long as you're using the same Google log in I don't see why you couldn't just reinstall the apps without an extra charge.
    deleted by author
    Senior Member Con5150's Avatar
    Bronx NY
    Thanks guys......help is never too far away here.
    Senior Member AirborneDude's Avatar
    Southern California
    Yeah, thanks for all the info. I am going to wait before I install Zeam.
    Bronx NY
    So I ended up doing a factory reset....phone was so laggy the past few days....thing is....all the apps I purchased are in the download section except the MLB app, and when I search for it I don't see it....how could that be?
    Bronx NY
    Anyone have any idea why the MLB At Bat 2010 is not showing in the market .....I had it before e I did the factory reset. i emailed the developer but no surprise on the non reply.
    Senior Member jmgib's Avatar
    Kentucky
    I'm guessing it has something to do with the copy-protection. Are you running the 13.35 update?
    I tried searching for it myself (and even tried using the QR code from Androlib) and can't find it in the Market either.
    Bronx NY
    Yeah , I have the update...that's one of the things I checked.....I would be curious to see if someone with a different phone running 2.1 could find it.
    Junior Member tmtolpa's Avatar
    houston, TX
    No you don't necesarily need to pay for an app you already bought. On the Motoblur site it tells you won't need to pay if you use the same username & PASSWORD IN THE MARKETPLACE?
