Two INCREDIBLY ANNOYING problems with my backflip!!! help!!!
This is a discussion on Two INCREDIBLY ANNOYING problems with my backflip!!! help!!! within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Whenever I'm listening to music, which I usually do at a low volume, and I push the power button to turn on the screen to ...
Thread: Two INCREDIBLY ANNOYING problems with my backflip!!! help!!!
    Junior Member shiftylock's Avatar
    Exclamation Two INCREDIBLY ANNOYING problems with my backflip!!! help!!!
    Whenever I'm listening to music, which I usually do at a low volume, and I push the power button to turn on the screen to change songs, about once every 20 songs or so it will turn my volume to max instantly, which tends to ruin not only my hearing but my headphones as well. Not to mention I jump about a foot in the air. Has anyone else had this problem?
    My other problem I've had (which is even more frustrating than the first) is that when people try to call me, usually while I'm texting, the phone will freeze and play my ringtone, but the screen won't change so I can answer the call! I miss about 1/3 of my calls this way, and it's getting to the point where people think that I just don't like picking up phone calls. Is there a button I can press to somehow answer a call when the screen is frozen like this? Or a third party dial that hasn't been destroyed by motorola/att? Thanks in advance...
    Junior Member Puppetxi's Avatar
    Not sure on the first one, but you should be able to hit the home key and then hit the call button to pick up the call. Also, can't remember but there also might be a notification on your drop down bar that you can pull down and click.
    Junior Member jonny.paine@yahoo.com's Avatar
    Oh my god yeahh I've had both those stupid problems.. well I know that even when the screen is locked u can still adjust your music vol with the side buttons. And about the call thing, I hate how it keeps playing your ringtone even while your screen is frozen. But I've noticed that only happens when u have the keypad flipped open and are in the middle of a text. There should be a way to edit your "answer call" options.
    deleted by author
  1. Confused about WiFi Calling
    Last Post: 05-10-2013, 03:00 PM
  2. Vibrant free for BOTH newAND upgrades.
    By DF Member in forum Samsung Vibrant
    Last Post: 10-29-2010, 06:35 PM
  3. Is Samsung goiung to fix bluetooth???
    Last Post: 09-19-2010, 03:07 PM
  4. Epic 4G Car Mount - Arkon Mega Grip Holder
    Last Post: 08-04-2010, 05:49 PM
back flip problems
backflip problem call
cant do and recibe calls motorola backflip problem
does motorola backflip hangs
fixing screen on backflip
home key on the backflip doesnt work
how to fix the motorola backflip freeze
low backflip problem
motorola backflip always freezes
motorola backflip freezing
motorola backflip home button not working
motorola backflip problems
motorola backflip screen freezes
motorola backflip screen issues
motorola bakflip keys not working
