Sim Card Problems
This is a discussion on Sim Card Problems within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I imported my contacts from my old phone off of my SIM, but they didn't transfer right. The names are messed up. I've deleted them ...
Thread: Sim Card Problems
    Junior Member mikokit's Avatar
    Sim Card Problems
    I imported my contacts from my old phone off of my SIM, but they didn't transfer right. The names are messed up. I've deleted them all, and added them back on, but the messed up version of the names are still visible when I send a text. I want to know how to delete my contacts from my SIM card. I don't mind having to add all of my contacts back by hand.
    Senior Member jmgib's Avatar
    Kentucky
    You should be able to just delete them. You may want to check at Google to see that they haven't been sync'd with Google.
    Member sal2708's Avatar
    yeah your proble is that they are backed up with google, go to your account on your computer and delete all your contacts. problem solved!
    No, that didn't fix it. It really is a problem with my sim card. My last phone was four years old, and when they transferred my contacts off of it onto my new sim card, it messed up the format. I need to know how to access my sim card information from my phone so that I can clear my contacts off of there.
    Oh hey, I found it. Damn, this phone has a lot more options than my old one. >_< It was in the side menu, center, second page. Manage SIM Card. Thanks for the tip about google contacts though! I'll be able to add them in much easier that way.
  1. How to Convert Movies to MPEG-4, H.264 or AVI Supported by PSP
    Last Post: 12-23-2010, 01:31 AM
android phone sim problems
android sim card problem
android sim card problems
backflip not recognizing contacts on sim
backflip problema simcard
www.android sim card problem
