Changing ringtones
This is a discussion on Changing ringtones within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Hi. I am wondering how to change the ringtone. I mistakenly chose a song for a ringtone. When I went to settings and changed the ...
Thread: Changing ringtones
    Junior Member kkaiser48's Avatar
    Changing ringtones
    Hi. I am wondering how to change the ringtone. I mistakenly chose a song for a ringtone. When I went to settings and changed the ringtone on the screen, it did not change it from the song. No matter what I selected, the ringtone wouldn't change. I finally took AT&T music off of my desktop. That replaced the song with the sound of an old fashioned phone ringing. That is not even an option in my ringtones (as far as I can find). I know I am missing something. Can you give me the steps to change ringtones? I have googled it but cannot find a solution. Thanks.
    Senior Member jmgib's Avatar
    Kentucky
    When setting the ringtone, you have the option of built in "generic" ringtones, or you can use music on your phone. It also should give you the chooser for which you want to use, unless you set on of them as default, which it sounds you may have.
    thanks
    How can I tell if I set up a ringtone for default? That is entirely possible. I have had the phone for a little over a month and I can't put the thing down!! I can't tell you how many times I have changed the looks of my screens!! Haha. This is the first time I have changed the ringtone (inadvertently). I may have just opened a whole new can of worms!!
    deleted by author
    Thanks Marvin
    Thanks Marvin. I'll give that a try!
  1. Adjust unlock time
    Last Post: 10-24-2010, 01:05 AM
  2. HTC Aria Forum
    By TMODroids User in forum Off-Topic Forum
    Last Post: 07-10-2010, 01:14 PM
change default ring for the motorola
change ring tones
change ringtone motorola backflip
changing ringtones
default ringtone motorola
how do i change default ringtone on motorola
how to change default ringtone on motorola
how to change default tones on a motorola
how to change ringtone on motorola blur
how to change ringtone on motorola flip phone
how to change ringtones on motorola backflip
how to change tingtone on backflip
how to personalize ringtone in motorola backflip
how to set ringtone on motorola flip phone
ringtone location backflip
