Front Facing Camera
This is a discussion on Front Facing Camera within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Has anyone figured out how to use the front facing camera yet? If so please provide instructions....
Results 1 to 10 of 11
Thread: Front Facing Camera
    Junior Member hoosier1104's Avatar
    Question Front Facing Camera
    Senior Member jmgib's Avatar
    Kentucky
    There is only 1 camera on the Backflip. To use it "front facing" you simply open the keyboard and aim it at your face.
    Then what is the circle lens thing next to the speaker?
    Kentucky
    Proximity sensor. Detects when you have the phone up to your head. Shuts the screen off so you don't hit the buttons with your face.
    Ok. That makes then. Not sure why I thought it was a camera.
    Junior Member asiangamer29's Avatar
    Quote Originally Posted by hoosier1104 View Post
    ur right but ur wrong, there is a proximity censor and a camera with a flash that looks like the same on the keyboard side
    look carefully, with a strong bright flashlight, u'll see a yellowish thing on far right hand corner on the touchscreen side which is the flash, then slightly right and above the censors, u'll see the mini camera, so...
    and plz reply if u finally notice the second camera and if ur able to tell me how it works?, and the only other explanation is that my cousin said its probaly for a video chat or something like that
    Kentucky
    The Backflip only has 1 camera, the one on the back with the physical keyboard. There is no "front facing camera".
    Member kamelonious's Avatar
    not a designated one, no. but there is a front-facing one if it is "backflipped". woo.
does a .3 front facing phone camera do an ok job?
does a motorola blur have a forward facing camera
does motorola backflip have front camera
does motorola backflip have front facing camera
does the backflip have a front camera
does the motorola backflip has a front camera
does the motorola backflip have a front camera
does the motorola backflip have a front facing camera
does the motorola fire have a front camera
how to restore front camera on motorola
how to use front camera on motorola backflip
motarola backflip camera features front fae
motorola backflip front camera
motorola backflip have a front camera?
what does a front facing camera look like
