About Advanced Task Cleaner Pro
This is a discussion on About Advanced Task Cleaner Pro within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; So my Advanced Task Cleaner Pro app is in the top bar. When I go and exterminate all things running, after a couple seconds IM ...
Thread: About Advanced Task Cleaner Pro
    Junior Member Unexpected's Avatar
    So my Advanced Task Cleaner Pro app is in the top bar. When I go and exterminate all things running, after a couple seconds IM and Motoblur and a couple more things pop up. It's weird because I didn't click on them again. I'm guessing it's because of Motoblur on the phone and I know I can't turn off Motoblur but why does that happen to me?
    Senior Member jmgib's Avatar
    Kentucky
    Some apps cannot be killed. Happenings, IM, and especially Motoblur are some of those apps. As part of Motoblur even if you kill them with a task killer they will autorestart after a few seconds (even if you do not have the widgets running).
  1. Samsung Epic 4G vs Blackberry Torch 9800
    Last Post: 08-09-2010, 11:00 PM
advanced task cleaner pro
advanced task cleaner pro faq
