Weird behavior when trying to charge my Backflip
This is a discussion on Weird behavior when trying to charge my Backflip within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I have had my backflip for a little over month with zero problems until this weekend. I was at my mom's when I plugged my ...
Thread: Weird behavior when trying to charge my Backflip
    Junior Member slm32006's Avatar
    I have had my backflip for a little over month with zero problems until this weekend. I was at my mom's when I plugged my data cable into a USB port on her XP desktop. Windows goes through it deal searching for a driver to install. Can't find one. So unplug the phone from the cable (I ejected the device from Windows, first, before unplugging). Go to the Motorola site and get the drivers. install them. plug the phone back in. windows recognizes the phone and installs just fine. i soon get the popup screen asking to charge only or usb drive. when i pick up the phone to make my selection, i notice the led flash is on and the keyboard is lit up. (the phone is in its normal position without the keyboard flipped open). now it is impossible to charge because the led flash either gets the phone too warm or is consuming more energy than is being charged. luckily my girlfriend has a backflip so i have to swap batteries with her. Both phones have been updated to 13.37 and hers is working fine. my has worked for about a week or so after updating before this problem has occured.
    has anyone had the type of issue??? and if so, the fix.
    right now, a Captivate is looking very appealing.
    thx
    slm32006
    deleted by author
    thanks for the reply.
    it does the same thing when using the wall changer. and it's the charger that came with the phone. my other two changers. another wall charger and a car charger where bought from walmart. up until last week both of those chargers worked fine as well.
    deleted by author
backflip blink when charging
backflip green light blinking
backflip issues when charging
blinking charge light motorola backflip
charger blinking on motorola backflip
charging motorola backflip usb issue
motorola backflip charge blink
motorola backflip charger light blink
motorola backflip charging led
motorola backflip flashing green
motorola backflip green light blinking
motorola backflip usb charge
problems charging motorola backflip
what does it mean when a backflip phone charger blinks
when i plug my backflicp into the charger it blinks
