Backflip not restoring....ugh
This is a discussion on Backflip not restoring....ugh within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I have been having some rebooting and black screen issues with my backflip since the recent 13.37 update. I want to try doing a factory ...
Thread: Backflip not restoring....ugh
    Member peteseiler2010's Avatar
    Unhappy Backflip not restoring....ugh
    I have been having some rebooting and black screen issues with my backflip since the recent 13.37 update. I want to try doing a factory reset, but when following the instructions it says to release the camera button, then hold volume down and a selection screen will pop up. When I hold volume down, it says volume up key pressed and it just sits on a screen with a yellow exclamation point and does nothing. Anyone else have this problem?
    Senior Member Joe Coolcool's Avatar
    That hasn't happened to me.
    If you tell one of the reps at an At&t that your phone messed up while you were updating it, they might give you another one.
    Credit goes to ee0r.com for my avatar.
    Senior Member jmgib's Avatar
    Kentucky
    What instructions are you following to do a factory reset? All you need to do is go into Settings -> SD Card & Storage -> Factory data reset
    I was trying the hold power and camera button, the release camera and hold volume down. I lost my book and did a Google search for the reset.
    Junior Member geekman's Avatar
    i have had the same problem (im still researching how to fix my phone but heres my story) so like one day my phone works great no problems then i left it on for the night the battery dies, i plug the charger up (i get the usual status for charging) so then i turn it on and the phone hangs on the motorola boot screen. pull the batt. tried it like 4 times, then i try to reseat the simm card (no fix) the same with the memory card, so in an attempt to fix it (and from what i remebered reading) i pull and replace the batt. hold the pwr. and camera button to start the boot settings.
    heres the funky thing if i press up for one setting it thinks i hit down so i hit up for down to do the restore process and i get a message that says *(this is not word for word but i will update this when i get the phone back from my buddies (cause i left it) ) recovery failed security lock and somethign about usb or sumthing (i dont think my battery was fully charged maybe thats why)
    any ways thought i might chime in here
    im running
    the new update 13.xxxxxx (a few weeks ago)
    (sry for the typing i tend to type messy on these)
    deleted by author
    thank you i seems i was using the wrong menu in the boot loader you select verbose boot and then wait for the phone and triangle , ...... as mentioned on the first link above thankyou
backflip yellow exclamation
flipside black screen
how to fix motorola backflip black screen on boot
motorola backflip black screen after upgrade
motorola backflip black screen exclamation
motorola backflip stuck hard reset
motorola backflip stuck on triangle
motorola flipside black screen
motorola flipside black screen problems
motorola flipside hard reset
motorola flipside hard reset#gsc.tab
motorola flipside menu button goes to black screen
motorola flipside stuck on triangle
motorola flipside will not turn on with a new battery
my motorola backflip screen black
