3G Activates when phone is idle
This is a discussion on 3G Activates when phone is idle within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Yes but I suppose JM has a point there. In area of weak 3g reception wifi may be the better option. The important thing to ...
Results 11 to 13 of 13
Thread: 3G Activates when phone is idle
    Yes but I suppose JM has a point there. In area of weak 3g reception wifi may be the better option. The important thing to remember is to turn wifi off when your leaving the reception area otherwise the phone constantly looks for a wifi signal and will drain the battery quicker.
    Member wikidcerealkilla_attdroids's Avatar
    Just read up on this a little bit more... it says th wifi drivers will go to "sleep" also due to lack of inactivity, but are very unreliable on waking, so it says its almost better to keep it the way it is
    HTC Aria Cyanogen 6 overclocked to 845mhz using Tapatalk Pro
    HTC Aria... rooted
    Clockwork recovery
    CYANOGEN 7 Gingerbread
    Overclocked to 805 MHz
    Former phones...
    HTC G1... that I have since rooted and gave to brother.
    Motorola Backflip... many calls and replacements till they gave me the Aria
    IPhone 3g... enough said
    Senior Member jmgib's Avatar
    Kentucky
    I have my wifi set to never sleep and rarely ever have any issues with it. There has been maybe 2 or 3 times where I have had to cycle the Wifi off and back on, but ymmv.
3g idle mode
3g inactive on android
android idle saver edge only
how to keep 3g in idle mode
htc aria turning off and on
is it ok to leave wifi on when phone is idle
motorola 885 screen keep coming on even when idle
motorola backflip sleep mode
turn off wi-fi when phone is idle
turn off wifi sleep mode htc aria
what is 3g idle mode
