Member
3G Activates when phone is idle
I have a feeling this may have something to do with my task killer (Task Manager), but every time I unlock my phone from idle/sleep mode, I notice that the 3G icon is active in the task bar (even though I'm at my home/network) and then the phone goes back to wi-fi mode after a few seconds of it being unlocked. Wi-fi is turned on, of course.
I'm just worried that my phone could be using more battery and data with 3G while it is idle, when it should only be connected to wi-fi unless, of course, I go out of range of my network.
08-22-2010 03:22 PM
# ADS
Member
That's cause when ur phone idles or goes to sleep it reverts back to ur phone wireless connection... go to ur WiFi settings menu, wireless, WiFi settings... hit the menu button, click advance settings, then click WiFi sleep policy and hit never. Hope that helps
Member
Ah, yes it was set to "When screen turns off". That should do it. Thanks.
Member
The other thing you MAY run into as a problem, When The Phone is in "sleep" mode (if you will) often times it wont show what network you're connected to...I caught this when I was outside of my Sheriff's Office the other day (WiFi and the Edge Network were both active) The phone didn't show any network signature (it didnt Say 3G or EDGE) it just had the signal Bars...I ended up having to turn the Wifi off to make a phone call..Happened to me several times now actually...
Ignorantia Juris Neminem Excusat! - Ignorance of the law excuses no one!
Member
Really? When i turn on the wifi and connect to a server it always turns my wireless net off... dont need em both running... i still was able to make calls fine tho. Thats a problem you should look into more cause i believe by default it turns off your mobile web
HTC Aria Cyanogen 6 overclocked to 845mhz using Tapatalk Pro
HTC Aria... rooted
Clockwork recovery
CYANOGEN 7 Gingerbread
Overclocked to 805 MHz
Former phones...
HTC G1... that I have since rooted and gave to brother.
Motorola Backflip... many calls and replacements till they gave me the Aria
IPhone 3g... enough said
Super Moderator
I agree with Diesel984. My BF gets confused sometimes too, and doesn't know which connection to keep active. Until I hold the power button for a second and turn off the WiFi, it holds both WiFi and 3G open, but doesn't let you use either. But turning the WiFi off, then back on solves the issue for me.
Senior Member
Originally Posted by
Casual-T
I do not recommend that if battery life is a concern. It will save battery to leave it as is and let it reconnect on wake up otherwise you will be transmitting data the entire time. Where as when it switches back to 3G it only uses data as needed.
Member
How does that cause more battery... if u change that setting it should run you off wifi only and not your mobile web... thus saving you battery power.
HTC Aria... rooted
Clockwork recovery
Former phones...
Senior Member
In the case where you are in an area with weak signal, it actually saves the battery to have the wifi never sleep. This is because it takes less power to maintain a strong Wifi connection as opposed to constantly trying to maintain a weak data connection.
If you are in an area with strong cell signal this may not be the case, but even still I suspect it would be. Now, if you are in an area where there is no Wifi signal you can save battery life by disabling Wifi. But if you do have Wifi it's more efficient to maintain that connection.
Member
TechN9ne1730
Aaahhh i get what your saying now... wifi on is always gonna be running as with the 3g is only gonna run when it needs it. Like to update a widget or whatever. But even then on wifi... it gonna idle till it needs the information so it wouldnt be transmitting anything really, and thus saving on battery
HTC Aria... rooted
Clockwork recovery
Former phones...
