SD cards issues
This is a discussion on SD cards issues within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; so whenever i try and add a file from my cpu to my phone the computer shows an error message and wont allow me to ...
Thread: SD cards issues
    Junior Member beamer1341's Avatar
    SD cards issues
    so whenever i try and add a file from my cpu to my phone the computer shows an error message and wont allow me to add anything to the sd card, Ive also tried doing this with just the sd card...same thing and whenever i try to erase a file from the sd card on my phone it says its locked but the sd card isnt actually locked any ideas
    Senior Member jmgib's Avatar
    Kentucky
    This has come up several times. Usually this is caused because the SD Card was not properly unmounted from the PC before the phone was disconnected. This corrupts the data on the SD Card. Usually the answer I believe is to format the SD Card again. Sometimes you can get lucky and get it to mount on a PC. Try connecting in an SD Card reader if you have one available.
android motorola error files sd card
atrix erases files on sd card
how can you unlock your sd card on a devour phone?
how to unlock a sd card on a devour
how to unlock a sd card on a motorola devour
how to unlock an sd card on a motorola devour
how to unlock motorola devour sd card
how to unlock sd card on motorola blur
how to unlock sd card on motorola devour
how to unlock your sd card on a devour
motorola backflip sd card not reading
motorola devour locked sd card
motorola devour wont unlock sd card
sd card problem motorola backflip
sd not showing backflip
