Android system maxes CPU.
This is a discussion on Android system maxes CPU. within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Title says it all. Brings my system to a grinding halt. Anyone else having similar issues?...
Thread: Android system maxes CPU.
    Junior Member rengreco's Avatar
    Senior Member jmgib's Avatar
    Kentucky
    Actually title doesn't say it all. When did it start happening? Did you make any changes to the phone before it started? Have you rooted your phone? Is so, have you removed anything?
    Avatar courtesy of Elliott C. 'Eeyore' Evans @ www.ee0r.com
    It has been happening intermittently, phone is rooted, I had not made any changes to the phone prior to its happening. I do not know if this has happened prior to rooting but I would say that it happens quite frequently, I experience this daily if not several times a day. I have removed some apps all were on the official safe to remove list with one exception the ATT music app. I have another app installed and it was of no use to me.
    Kentucky
    When it is happening, is the sync icon visible on the notification bar? The only time my phone is almost unresponsive, is if I have been without a data connection for awhile and then reconnect. While the phone is syncing it does make the phone very sluggish until the process completes.
android system max cpu
android system server high cpu
system server cpu 100
