I'm facing a problem with the bluetooth
This is a discussion on I'm facing a problem with the bluetooth within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I'm getting an error like "Paired but not connected". Can any one tell me why it is happening. I selected both discoverable and bluetooth on..what ...
Results 1 to 9 of 9
Thread: I'm facing a problem with the bluetooth
    Junior Member Priya raj's Avatar
    I'm getting an error like "Paired but not connected". Can any one tell me why it is happening. I selected both discoverable and bluetooth on..what else i have to do. I can see other bluetooth profiles on my mobile. Please reply to this with a solution.
    Senior Member jmgib's Avatar
    Kentucky
    What are you trying to connect to your phone? A headset? car stereo? another phone?
    Can you please provide more detail?
    I'm tring to connect with other mobiles. I can pair the number but the error is like "paired but not connected". I have switched on the bluethoothon other mobile. It is visible on my mobile. My bluetooth name is also visible on other mobiles but not always.
    Member jdsatyr's Avatar
    in the case of 2 phones connecting the second (noninitiating) phone has to accept the connection
    every thing is done, both the mobiles got identified and paired. But not connected.on the other moblie, it is showing "The other mobile is not supported". It means my mobile is not supporting. What to do in this case..??
    Kentucky
    I don't believe the Backflip supports transfers over bluetooth out of the box. You may try installing Bluetooth File Transfer to see if that will work for you.
    Also, you didn't say what exactly you are wanting to do. I'm presuming you are wanting to transfer files/ringtones, but this is just a guess.
    Unhappy Same...problem...
    I tried with the bluetooth software installing Bluetooth File Transfer. But no use..wat to do..is there any solution are not..? will motorola back flip supports bluetooth file transfer..i'm very much worried about this..
    Junior Member techclan's Avatar
    Did you try going to Settings -> Wireless Controls -> Bluetooth Settings and clicking on your device on the bottom of that page to connect it ?
    Junior Member gamertv's Avatar
    i am facing the exact same issue.
    i
bluetooth issues with android and other phones
bluetooth paired but not connected what does that mean
what does bluetooth not supported mean
what does bluetooth paired but not connected mean
what does it mean when bluetooth is not supported
what does it mean when bluetooth is paired but not connected
what does it mean when bluetooth says not supported
what does it mean when bluetooth says paired but not connected
what does it mean when your bluetooth is not supported
what does it mean when your bluetooth is paired but not connected
what does not supported mean on bluetooth
what does paired but not connected mean
what does paired but not connected mean bluetooth
what does paired but not connected mean on bluetooth
what does paired not connected mean
