Can't clear default "Home" in 2.1 the beta rom
This is a discussion on Can't clear default "Home" in 2.1 the beta rom within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Under 1.5 when you had multiple "home" applications you just had to go to manage applications, find the "Home" application, and clear the preferred application ...
Thread: Can't clear default "Home" in 2.1 the beta rom
    Junior Member RonV's Avatar
    Hoffman Estates, IL
    Under 1.5 when you had multiple "home" applications you just had to go to manage applications, find the "Home" application, and clear the preferred application preference.
    In the beta ROM you no longer have a "home" application listed. LauncherPro is listed as as expected it's not defined as the default application.
    Any idea's how to clear the "default" home preference when it's not listed in the manage applications list?
    Senior Member jmgib's Avatar
    Kentucky
    Try installing and using Home Switcher to change and set the default launcher app.
    Hoffman Estates, IL
    Thanks Home Switcher worked.
    Junior Member 93accord's Avatar
    You could also go Settings > Applications > Manage applications > Filter > All and then select Layer Pro and clear the defaults that way instead of needing to install an additional app.
    Kentucky
    Quote Originally Posted by 93accord View Post
    You can do that, but if you have several launcher apps installed, Home Switcher is a nice and easy way to switch between them.
android can't clear defaults
can't clear defaults android
can't clear defaults in android
cannot clear internet as default app android
cant clear internet defaults android
clear default in home settings
clear default launcher
cleardefaulthome
how to clear default in home settings applications manage appications in samsungs s4
i can't clear default
i can't clear defaults
