Moto Backflip Help!!
This is a discussion on Moto Backflip Help!! within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Downloaded a ROM App from the Marketplace after Rooting my phone. Well I places the wrong ROM on the phone and used the App to ...
Results 1 to 10 of 13
Thread: Moto Backflip Help!!
    Junior Member Finisher1214's Avatar
    Well I places the wrong ROM on the phone and used the App to flash it.
    Phone went off I turned it on and stays at the Motorola Boot screen and goes no were.
    I tried holding the power button and camera button and then I pressed what everyone told me to press and the screen stays and says you have pressed Volume Up.
    I cant seem to do anything. Help please
    If someone can give me an idea or something or help me I would really applicate it.
    Member Jellono's Avatar
    Quote Originally Posted by Finisher1214 View Post
    Ok it appears you have "Bricked" your phone..
    Here is how to recover from it..
    [Instructions] How to flash your phone
    Not too hard if you have "Rooted" you should be able to get thru this easly..
    It will return you to 1.5 and you will need to re root..
    Dave.
    PS.. 5 minutes is a really short period of time between your "Desperate" posts.. you really should excursive the search feature these problems have been talked about over and over again on this and other forums..
    I want to thank you for your help. I love you. BTW no homo
    Ok I followed it and everytime I start to flash it says Fail. I downloaded many different versions
    Well you should only flash the version for your backflip ie Us etc
    As for your problem???? You need to be more exact
    1. What backflip do you own?
    2. What is the exact error
    3. Which step failed you?
    1. Umm how do I find that out
    2. Umm it just says fail
    3. It went to 100% then 100% I think one more then it said fail
    Failed flashing process. said twice Phone[0000]: Error sending JUMP command Device API Error: 0xE0030040 Address: 0xB0000 cant see the rest to type
    Ok so Here are the steps verbatum.... One of these failed?
    What you are going to need:
    • Rsdlite 4.5.7 or higher (find on google)
    • Motorola drivers for your system (windows only)
    • Firmware suitable for your phone (same version or higher and also made for your phone)
    How to flash:
    • Install rsdlite
    • start your phone in usb boot loader mode (hold d+j while pressing power)
    • connect phone to pc with usb cable
    • open rsdlite (open with administrator rights)
    • check your phone is seen by rsdlite
    • browse for the firmware (This part is important!!)
      you should put this in the root of your c: drive and call it flash.sbf or something simple without special characters or spaces
      still has to end with .sbf
      It won't work otherwise!!
    • hit start
    • wait till it has finished
    • It might reboot back to a recovery screen or blue screen, just take out your battery for 30 seconds, then replace and press the power button
    Did you buy Your phone in the united states?
    China?
    Canada?
    Here is the list of roms..
    Branding: AT&T US
    Version: 0.12.1199
    Secure Version: 0006
    Bootloader Version: 05.12
    Requires RSD Lite 4.5.7.
    Requires Moto Android (De)packer 1.2 to edit.
    Branding: AT&T US
    Version: 0.13.35
    Secure Version: 0009
    Bootloader Version: 05.13
    Branding: AT&T US
    Version: 0.13.37
    Secure Version: 0010
    MOTUS - ME600 / BACKFLIP - EMARA MB300
    Branding: Generic Chinese
    Version: 00.00.34
    Secure Version: 0005
    Version: 00.10.8
    Bootloader Version: 05.17
    Branding: Retail Italian
    Version: 0.1.2
    Version: 0.3.6
    Branding: Optus Australia
    Version: 0.2.3
    Version: 0.2.9
    Branding: Retail German
    Version: 0.2.9
    Version: 0.2.12
    Branding: Retail French
    Version: 0.3.6
    Branding: Retail British
    Version: 0.3.7
    BACKFLIP - LATAM MB300
    Branding: Personal Argentina
    Version: 0.12.712
    Bootloader Version: 05.01
    I am suspecting you may live in one of these countries or purchased the phone in one of them??
    Finisher1214, there is an edit button, Also give people more time then 5 minuets to reply. As for the problem, it may help if you could tell us what app and rom your referring to..there shouldn't be any ROMs in the market..
  1. Replies: 0
    Last Post: 01-03-2011, 04:53 PM
backflip - retail italian 0.3.6
backflip rsd error send jump command
baixar rom mb300 sbf
branding: at&t us version: 0.12.1199 android version: 1.5 secure version: 0006 bootloader version: 05.12 requires rsd li
branding: generic chinese version: 00.00.34 android version: 1.5 secure version: 0005 bootloader version: 05.12 requires
descargar retail italian 0.3.6.sbf para motorola mb300
error sending jump command device api error: 0xe0030040 address: 0xb00000 command: jump
error sending rqsf boot command. device api error: 0xe0030040 command: rqsf
error: phone[0000]: error sending jump command device api error: 0xe0030040 address: 0xb00000 command: jump
me600 1.5 sbf
moto depacker
moto me600 backflip rom
motorola backflip rsd lite error sending jump command
retail german 0.2.12 download
sbf motorola me600
