Problems syncing music to my Backflip
This is a discussion on Problems syncing music to my Backflip within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I am so aggravated! I use Windows Media Player version 12 to sync songs to my Backflip. It seems like some files will copy over ...
Results 1 to 10 of 11
Thread: Problems syncing music to my Backflip
    Junior Member jockewing's Avatar
    I am so aggravated! I use Windows Media Player version 12 to sync songs to my Backflip. It seems like some files will copy over with no problem, but about 40% of the songs on my computer will not sync. Sometimes even within the same album some of the songs will sync and others wont. The ones that won't sync aren't protected and they are just regular .mp3 files. The songs that won't sync to my phone WILL sync to my cheap-y mp3 player, so I know there is not a problem with the file itself.
    Can someone please help? It seems like half the time my computer will not recognize that the phone is connected in the device manager, and I sometimes have to exit out of media player and restart it to get it to recognize the phone is connected.
    Are there drivers or something I need to download to my computer to fix this problem or is it something else? It is so annoying to download music and then it won't sync!
    Hello, anyone?
    deleted by author
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    ^Either that, or use Motorola Media Link.
    Quote Originally Posted by jockewing View Post
    Hello, anyone?
    Hello, could you learn to be patient and give people more then an hour to reply? Some of us dont scour the forums daily hitting the refresh button 24/7.
    @Marvin, personally I use /sdcard/audio for my music, and /sdcard/ringtones for ringtones.
    deleted by author
    Tech9, I waited 5 DAYS, not an hour to ask if anyone had a response. That doesn't seem unreasonable.
    Android Lurker panapower's Avatar
    Nov 2011
    NOLA
    i know i'm reviving an old thread but where is the /sd card file located when i plug the phone into my computer? I see all the other folders on my phone but i dont see the SD Card file. Thanks for y'alls help. I really appreciate it.
    Nov 2011
    NOLA
    These are the only folders I have on the phone....
    • blutooth
    • browser
    • burstlyimagecache
    • com
    • DCIM
    • download
    • dropbox
    • foursquare
    • logs
    • LOST.DIR
    • Messaging
    • mgdata
    • mobile
    • podcast
    • sb2
    • slacker
    • torus
    • twc-cache
    • where
    • yahoo
    • ypmobilelistimgs
    • albumthumbs
    • agilefusion
    • .medieval_software
    • .blur
    • Android
    I dont see the SD Card in there at all!!
    deleted by author
  1. Radio Shack offers T-Mobile G2 For $149
    Last Post: 09-14-2010, 05:43 PM
.mediaval software android
.medieval software
.medieval software folder
backflip media player issues
burstlyimagecache
my backflip wont play certain songs
problems syncing music on motorola android
syncing to mb300
what is .medieval software.
ypmobilelistimgs
ypmobilelistimgs folder
