2.1 help
This is a discussion on 2.1 help within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Just installed the 2.1 update off of the motorola website and mow my phone will not go all the way through the start up procedure. ...
Thread: 2.1 help
    Junior Member Dmoser's Avatar
    2.1 help
    Just installed the 2.1 update off of the motorola website and mow my phone will not go all the way through the start up procedure. It starts with the motorola logo and then goes through the startup sequence but as soon as it gets to the att part it freezes. Does anybody else have this issue and if so can anybody help me?
    Nevermind, just got it to work O.o
    Junior Member ld777's Avatar
    How did you get it to work? Mine is doing the exact same thing. It has been going for some time now, it keeps rebooting , then gets stuck at the white at@t scren, then seems to keep going through that same cycle.Does anyone know how to get this to boot up all the way?
    ok never mind. not sure what happened but my son has the same phone, his updated way quicker than mine. Odd but after about an hour it finally booted up.
