MMS Disabled & APN not configured on my Backlip
This is a discussion on MMS Disabled & APN not configured on my Backlip within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; So, I've been able to send and receive MMS for a while, but these past few days my phone won't let me do either of ...
Thread: MMS Disabled & APN not configured on my Backlip
    Junior Member dnbayaa174's Avatar
    So, I've been able to send and receive MMS for a while, but these past few days my phone won't let me do either of the two. I have the app Quick Settings that lets me enable mobile data, but when I enable it, it says that I have no APN configured. Help??
    Senior Member jmgib's Avatar
    Kentucky
    What changes did you make to the phone before you began having issues?
    The only thing I've done is update it to Android 2.1, but after the update I could still receive MMS and use mobile data. Other that that, I haven't made any changes to my phone.
    Kentucky
    Are you using the phone on ATT's network? I don't believe I have seen any other reports of the APN just mysteriously disappearing after performing an official upgrade to 2.1.
    Yes I'm on ATT's network. This isn't the first time it has happened either, but it usually works after I turn my phone off and on. It's been like this for a few days now though.
apn blur att
apn blur simlpe mobile
apn for blur simple mobile
apn settings for motorola backflip
backflip apn att settings
backflip won't keep apn
cannot edit apn on motorola backflip
cannot recieve mms if mmsc not configured
change apn motorola backflip
change apn settings motorola backflip
enter apn in motorola backflip
how to change apn in motorola backflip
motorola backflip apn
motorola backflip simple mobile apn
will the motorolla backflip work on simple mobile
