Running Very Slow after upgraded to 2.1
This is a discussion on Running Very Slow after upgraded to 2.1 within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I notice the phone is running extremely slow after I upgraded to 2.1. Many of my game are to slow that it's impossible to play. ...
Thread: Running Very Slow after upgraded to 2.1
    Junior Member toiday's Avatar
    I notice the phone is running extremely slow after I upgraded to 2.1. Many of my game are to slow that it's impossible to play. Does any one have the same problem?
    I've heard of a few people who had this issue. Have you tried a factory reset.
    Senior Member jmgib's Avatar
    Kentucky
    I would also suggest performing a factory reset to see if that helps with the slowness that you are reporting. Also, what are some of the games that you are playing?
    Junior Member carebearlulu's Avatar
    yes it has it is very sluggish and also mine tends to restarts itself.
  1. Replies: 1
    Last Post: 09-17-2010, 01:26 PM
moto backflip going slow
motorola backflip moving slow
motorola backflip slow?
motorola backflip sluggish
motorola blur running slow
motorola blur slow
motorola blur very slow
motorola cliq running slow
motorola cliq slow after update
motorola cliq very slow
motorola dext speed very low itdunya
motorolla cliq extremly slow
my motorola backflip is so slow
why is cliq running so slow
why is my motorola blur so slow
