Backflip Stuck on White screen,Recovery not working
This is a discussion on Backflip Stuck on White screen,Recovery not working within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; I was making a backup of my ROM today and after it finished it restarted and wont boot back up. Ive tried, Cam + Down ...
Thread: Backflip Stuck on White screen,Recovery not working
    Junior Member Critical Cool's Avatar
    Unhappy Backflip Stuck on White screen,Recovery not working
    I was making a backup of my ROM today and after it finished it restarted and wont boot back up. Ive tried, Cam + Down vol Hooking up to the computer. that's about it. Anyone else have any ideas? can I redo the ROM?
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    I thought it was just the Camera button + power... hold those until you get to a bootloader.
    Senior Member jmgib's Avatar
    Kentucky
    Dorian is correct, to get into recovery, you just need to hold down the Camera button while powering on the phone. Continue to hold it until you get a message telling you to release it. At the Fastboot menu, then you press the Down Volume button to select recovery.
    If that doesn't work, and I'm not sure why it wouldn't, you'll probably have to go the RSDlite+.sbf flashing route to restore your phone to factory and start over.
    Smile
    I think the recovery partition got messed up,cause it just sits on the "Down Volume button Pressed", I was backing up the ROM it finished and restarted the phone. I have the clockwork-mod recovery file on the SD card.
    final update: Did the steps here and back in business,thanks Dorian
    http://www.attdroids.com/forum/motor...-re-flash.html
    I
  1. Car Cradle
    Last Post: 12-02-2013, 04:29 AM
  2. saving apps to sd card
    Last Post: 12-21-2010, 01:07 PM
att backflip wont conr on
att motorla backflip wont load up
backflip not working
backflip stuck on white screen
motorola backflip boot
motorola backflip fast boot not working
motorola backflip screen is white with lines
motorola backflip stays at home screen
motorola backflip stuck at boot screen
motorola backflip stuck on boot screen
motorola backflip stuck on white screen
motorola backflip white screen
my motorola backflip always shows white screen
my motorola backflip stays stuck on start screen
why is my backflip not coming on
