2.1 install, now speed dial is useless
This is a discussion on 2.1 install, now speed dial is useless within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Got through with install as per Motorola site, everything loaded, came up, but now I can add names to speed dial but will not let ...
Thread: 2.1 install, now speed dial is useless
    Junior Member rbellah's Avatar
    Got through with install as per Motorola site, everything loaded, came up, but now I can add names to speed dial but will not let me call the added names, I can uninstall the though. Has any one had a bug like this? My Motoblur addresses are now not my main contact directory, the G-mail contacts are the default contacts in my contact numbers. Seems to be slower than 1.5.:confused:
    San Jose, CA
    It's not a bug, they changed the speed dial method. Add a contact to the speed dial list, then go back to the dialer and long press on whatever number you assigned to that contact. That will dial the contact.
    deleted by author
    Thanks will try the method you suggest
    Success, thank you!!!!
how to speed dial backflip
how to use speed dial on motorola backflip
how to use speeddial on motorola backflip
motorola backflip speed dial
using speed dial on motorola backflip
