Motorola Backflup Battery Life
This is a discussion on Motorola Backflup Battery Life within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Hey everyone, I am just wondering if anyone is having the same problem as me, i will charge my battery completely and it will die ...
Results 1 to 9 of 9
Thread: Motorola Backflup Battery Life
    Junior Member morkeyz's Avatar
    Apr 2011
    Unhappy Motorola Backflup Battery Life
    Hey everyone,
    I am just wondering if anyone is having the same problem as me, i will charge my battery completely and it will die within 5 hours of being on. I hardly use it, all apps are killed every hour and I have the phone in power saver mode with the backlight on the lowest setting. I also have nothing being able to run in the background. I have recently bought a new battery and charged it for 16 hour charge like i was told to, but even after that the same thing is happening. Any ideas, or anyone having the same problem? Thanks!
    Sincerely,
    Sad User
    Senior Member jmgib's Avatar
    Kentucky
    That is definitely not normal. First thing is I would probably turn off the auto killer. If you truly "hardly use it" it should definitely last at least a day if not more since I'm pretty sure the lowest battery mode disables data when the screen is off.
    Apr 2011
    It says when i check the battery tester and it says that the screen uses most of the battery like 62% just wondering if this was normal. Why would turning off the auto killer help?
    Kentucky
    If the screen is using that much of your battery you could try lowering your brightness or making sure the screen isn't staying on (try lowering the screen timeout).
    Disabling the task killer may benefit some since some apps are designed to just restart and if the phone is sitting idle, apps staying in memory shouldn't really be a problem. I'm definitely not an advocate for auto killers.
    Apr 2011
    Yeah thanks I have the screen timeout already at very low i think its two minutes. Now atleast three times a day i have to reset the phone because it is slow as anything and can barely do anything. I mean it will take atleast 2 minutes to open my contacts. Any ideas on this new problem? Thanks for your help so far
    Kentucky
    If you're meaning that after turning off your task killer, then you can try using an app like Autokiller Memory Optimizer which lets you adjust the memory threshold at which Android will kill apps to free up more memory.
    Apr 2011
    Uhm well i never actually deleted it i just took it off of auto kill and not because of this my phone has just been slowing down a lot. I have already tried turning the task killer on and off
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Indeed... That is probably the best idea. You need root to use it, but it's a brilliant tool. You can also do this with "Spare Parts" from the market.
    Junior Member lxtbattery's Avatar
    Oct 2011
    http://www.lxt-group.com/02/en
    oh, that is a good idea. just do that!
  1. HTC Desire HD Source Code Released
    Last Post: 10-25-2010, 12:55 PM
backflip battery
backflip battery problems
battery for motorola backflip
battery life of motorola backflip
motorola backflip battery dies suddenly
motorola backflip battery life
motorola backflip battery problem
motorola backflip charge problems
motorola backflip display killing battery
why does my motorola backflip die so fast
why does the motorola backflip.battery drain so.quickly
why is my backflip so slow
