My alarm won't stop going off every. ten. minuets. Please Help.
This is a discussion on My alarm won't stop going off every. ten. minuets. Please Help. within the Motorola Backflip Tech Issues / Bug Reports forums, part of the Motorola Backflip category; Hello, My name's Rachael, and I'm new to the forums. Hope every ones having a good day Sooo, anyway. My backflip's touch screen stopped working ...
Thread: My alarm won't stop going off every. ten. minuets. Please Help.
    Junior Member knufflerabbit's Avatar
    Jun 2011
    Exclamation My alarm won't stop going off every. ten. minuets. Please Help.
    Sooo, anyway. My backflip's touch screen stopped working about three months ago, and since I don't have insurance or anything, I've been managing. I can't use the touchscreen at all.
    Last night I made the mistake of setting an alarm for nine o'clock in the morning, unaware that I can only dismiss the alarm by sliding DISMISS on the touch screen. It wont shut up. I can now only tap the keyboard to set it to snooze, which I have to do every ten minuets.
    Every ten minuets it rings, or vibrates, and I can't make it stop repeating. It's very, very annoying, and also draining my battery ( Which is horrible to begin with)...
    Any insight would be fantastic.
    Senior Member jmgib's Avatar
    Kentucky
    Honestly without being able to use the touchscreen I'm not sure what you can do. How did you set the alarm to start with? Can't you follow the same process to just turn the alarm off?
alarm app alarm wont stop alarming
android my alarm won't stop going off
at&t motorola atrix alarm will not stop
iphone alarm app won't stop alarming
iphone alarm goes off without being set#gsc.tab
iphone alarm wont stop
iphone alarm wont stop going off
my alarm on my iphone wont stop going off
my alarm will not stop going off on iphone
my alarmes wont stop going off
my iphone alarm wont stop going off
my touch screen stopped working and my alarm is going off iphone
the alarm on my iphone wont stop going off
what to do if an iphone alarm wont stop going off
why won't my iphone alarm stop
