Battery Life
This is a discussion on Battery Life within the Motorola Backflip forums, part of the Motorola Android Phones category; That's interesting that you can charge a dead battery from a PC. I have not been able to do that from multiple PC's and the ...
Results 21 to 30 of 39
Thread: Battery Life
  1. #21
    Junior Member clivesay's Avatar
    That's interesting that you can charge a dead battery from a PC. I have not been able to do that from multiple PC's and the Motorola Rep told the store that a very low battery will not charge from a PC.
    You two must be some of the lucky ones! :-)
    I just took my phone off a full wall charge. I will let you know what performance I get today.
  2. #22
    Junior Member hooligan's Avatar
    I had the issue of a "very bad battery life" when I first got the phone. After day 3, I ended up doing a factory reset. Since then, my battery life has improved greatly. Right now, my Backflip has been off the charger since 7am on Saturday, and it is showing 58% battery life left. Now, my phone use over the weekend is pretty low. I checked emails every so often, and did a few web searches, and made two short calls lasting less than 2 minutes each.
    I believe the factory reset makes a difference. Why...not sure...but it does seem to help. And like you, I also deleted all the Motoblur widgets. Google sync is on, but only for contacts, as I don't use the calendar or the mail client. (my gmail account forwards to my other personal account). Location based services are off, as are Bluetooth, GPS, WiFi..etc. I turn them on as needed. For my company email, I use Touchdown, but have it sync every 15 minutes, Monday through Friday only. I manually check it on the weekend.
  3. #23
    Oh, and since the factory reset, my phone has been up for 19 days. I have not powered it down for any reason, and it has not rebooted. And to add to my weekend use, I also used the camera for about 10 photos.
  4. #24
    Senior Member batmania15's Avatar
    MA
    Glad to see everything is working out for you. Curious did you have any 3rd party apps installed prior to your factory reset, they could have been a contributor to your experiences as well.
    I have 9 lockerz invites if interested PM me.
  5. #25
    only a task manager, which seemed to be doing bad things. I tried stopping some system services, which was a bad move and broke a few things. The factory reset resolved those issues, and I didn't reinstall the task manager.
  6. #26
    Senior Member montREALady's Avatar
    Quote Originally Posted by clivesay View Post
    2. I took off both Facebook widgets and the newsfeeds. They are cool gadgets but really I don't need to see my status on my phone or the people's continous status. I also removed the text message widget. There is a Facebook app and you get all your notifications for FB, Gmail, Txt in the upper bar anyway. Plus, just hold down the home key and a shortcut to all recent apps are displayed.
    Did you just drag them into the trash? Is that how you remove widgets?
  7. #27
    I know I've charged mine on my PC when it was less than 15% and after that warning.
  8. #28
    Junior Member myFirstAndroid's Avatar
    I just did several tests on battery usage. My Backflip is about 3 days old. I exchanged my old one for a new one.
    I had these off: GPS, Bluetooth
    I had these on: wifi, auto-sync, Mobile data, also gmail, browser, G map on background.
    The battery started on 90%. After 1 hour of idling, it was 85%.
    Then I charged the phone back to 90%, and turned off background apps, wifi, auto-sync. After 1 hour of idling, it was again 85%.
    So it seems to me that those common battery saving practices are not necessary.
  9. #29
    Quote Originally Posted by hooligan View Post
    The reason it seems to help, imo, is the phone, fresh from the store, starts off in a demo mode if you will with all those widgets preloaded on the desktop. Remember/Notice after a factory reset your default home screen has about 3 shortcuts on it rather then all those gadgets that require internet connection? Its my assumption these widgets continue to draw updates in the background when they shouldnt. Doing a factory reset fixes this.
    This shouldnt matter. Google sync, by my observations rarely updates. The other day I noticed that in settings it said google synch last updated at 8AM. It was around Noon when I looked at it. Thats a 5 hour period google did not update, so I am convinced this isnt needed to disable in regards to battery life.
    Quote Originally Posted by montREALady View Post
    Yes it is, but others said the best thing to do is perform a factory reset from the start. And you can use the multi-quote button to select multiple posts to quote at once rather then one at a time and double posting.
  10. #30
    I still recommend the Advanced Task Killer app. It's really amazing to look and see what all it has "killed" when you aren't using your phone.
  1. HTC Inspire 4G heading to AT&T with new Sense UI
    By danDroid in forum HTC Inspire 4G
    Last Post: 01-05-2011, 02:52 PM
android phone battery life starting dying
batmania15@gmail
battery draining on motorola blur
how do you make a motorola android battery last longer
how do you make your backflip battery life longer
how to make motorola flip battery last longer
motorola backflip battery
motorola backflip battery drain
motorola backflip battery drains very fast why
motorola backflip battery drianing really fast
motorola backflip battery life
motorola backflip battery life tips
motorola backflip dead battery
