Battery Life
This is a discussion on Battery Life within the Motorola Backflip forums, part of the Motorola Android Phones category; ok i jus got tha backflip and im having the same battery probs as anyone else. and when i go to settings, about phone, and ...
Results 31 to 39 of 39
Thread: Battery Life
  1. #31
    Junior Member beedrgn6's Avatar
    neeeeed heeelp
    ok i jus got tha backflip and im having the same battery probs as anyone else. and when i go to settings, about phone, and status, under battery status it says "discharging" when not on the charger. is that correct???? and the battery level drops from 100% to 92% after jus send a txt or two. plz some tell me what to do. i love this phone but after a hr or so of using it its already at 40% charge
  2. #32
    Senior Member Lendal's Avatar
    Quote Originally Posted by beedrgn6 View Post
    Wait... You went from 92% to 40% in about an hour???
    Something's seriously wrong. I'd take it back.
  3. #33
    Android Lurker Jhon Smitch's Avatar
    Spinning the hard drive uses the most battery power. Things like fast forward or rewind or having very big files. The backlight can save some but I doubt a whole lot.
  4. #34
    Quote Originally Posted by Jhon Smitch View Post
    Good advice.
    Except, of course, that there is no hard drive.
    You're just kidding with us, aren't you... Hope so, anyway.
  5. #35
    Senior Member Emcee's Avatar
    Eugene, OR
    I'm curious, when you guys kill apps using Advanced Task Killer, do you kill the killer itself, so to speak? Are there adverse effects to doing that?
  6. #36
    Quote Originally Posted by Emcee View Post
    No adverse effects.
    The apps you 'kill' are only removed from memory. It's like 'quitting' or 'exiting' an app except that it does that to apps that wanted to stay in memory.
    The next time you start them up to use them, they act normally.
  7. #37
    Eugene, OR
    Quote Originally Posted by Lendal View Post
    No adverse effects.
    I just meant killing the Adv. Task Killer app itself. I didn't think so, but I thought I'd check.
  8. #38
    Junior Member fonetek's Avatar
    This worked for me.
    Did you try doing a hard reset on the phone? I had the same problem with my backflip when I first got it. I would only get about 4 or 5 hours of battery life. I tried doing a hard reset, and after that I was getting a full day and a half to 2 days of battery life. I think there is something going on with the phone from when it comes from the factory. Possibly a debug feature turned on that they use for testing each unit. Hope this helps. I know this drove me crazy too, until I figured this out.
    regards,
    fonetek
  9. #39
    Junior Member Vardar's Avatar
    I actually noticed my battery life got better as time went on. As in, once I charged and killed the battery a few times, my battery life is pretty damn good right now. The task killer thing rocks btw.
  1. HTC Inspire 4G heading to AT&T with new Sense UI
    By danDroid in forum HTC Inspire 4G
    Last Post: 01-05-2011, 02:52 PM
android phone battery life starting dying
batmania15@gmail
battery draining on motorola blur
how do you make a motorola android battery last longer
how do you make your backflip battery life longer
how to make motorola flip battery last longer
motorola backflip battery
motorola backflip battery drain
motorola backflip battery drains very fast why
motorola backflip battery drianing really fast
motorola backflip battery life
motorola backflip battery life tips
motorola backflip dead battery
