LED's too bright for table-top mode
This is a discussion on LED's too bright for table-top mode within the Motorola Backflip forums, part of the Motorola Android Phones category; I want to use my phone as an alarm clock, but I cant keep the screen on because the LED's are blinding in the dark... ...
Results 1 to 10 of 12
Thread: LED's too bright for table-top mode
    Junior Member nickgottfred's Avatar
    Exclamation LED's too bright for table-top mode
    I want to use my phone as an alarm clock, but I cant keep the screen on because the LED's are blinding in the dark... I know that I can just turn off the phone because I don't need to look at the screen all night but... I like the clock mode, same thing with watching youtube videos. I called a motorola agent about it but I was connected to some woman in India who thought I was crazy.
    LEDs? The only LEDs are the white led for the camera flash, and the other is in the charging port. In table-top mode the camera LED is hidden and doesnt come on anyways, and the charger led, well I cant see how that would be so bright as to keep you up. It just glows a little while charging.
    Do you mean the LCD Screen?
    i think the OP is talking about the Home, Menu, and Back button are to bright. There is nothing that we can do about it. Its an issue going around a lot of boards.
    Member vasekvi's Avatar
    I read somewhere that there should be a fix for this in an upcoming firmware update. I refuse to use the tabletop mode until they do so.
    Junior Member azbackflip's Avatar
    have you tried the lightbulb icon on the clock? dims it pretty well
    Member Spooky Electric's Avatar
    Quote Originally Posted by azbackflip View Post
    People are complaining about the home, back, and menu touch parts of the screen. When you hit the dim light, those still shine VERY bright. There is a pick on the forum somewhere that shows this very well. They said that they called motorola and they told them that this has a been a giant complaint and will be addressed in the update. Hopefully it does get fixed.
    Junior Member hooligan's Avatar
    yeah...those lights will sear your retina in the dark. I have to keep my thumb hovered off those lights when using the phone in dim or low light, because I find those led lights too bright. I'd like an option to either dim or turn them off, and not just for the table top clock mode.
    Junior Member StuartG's Avatar
    I can't believe anyone did a usability study on this table top feature -- those buttons are so bright they will light up the entire room. I sure hope it gets fixed in the next update. In the meantime, I'm going to rig up something that just covers up those aircraft landing lights.
    Member Banstyle's Avatar
    Is there a way to turn off clock mode altogether? It comes on sometimes by accident when I don't have it open all the way. It wouldn't be an issue if it didn't put a notification in the menu every time you come out of it (pointless!)
    Junior Member jdavis's Avatar
    Until something is done with the Main LEDs all use of the phone in low light is a painful experience. Try the new Google Sky Map - with night mode - what a joke! All the dimming apps seem to have the same problem. What were they thinking?
    What about the battery drain from three super bright LEDs - could this explain why I don't get anywhere near the advertised battery life from a full charge?
  1. More details on Sony's PlayStation Leak
    By danDroid in forum Sony PSP Phone
    Last Post: 01-15-2011, 08:23 AM
android charger light glows bright and dims
android forums
how to turn on the led light on the samsung captivate
led clock too bright
led light shinning too bright
very bright led table light
