My observations regarding battery life
This is a discussion on My observations regarding battery life within the Motorola Backflip forums, part of the Motorola Android Phones category; i know ive heard it before, but i guess i was stupid for not thinking that ALL of the motoblur widgets were the issue, but ...
Results 11 to 15 of 15
Thread: My observations regarding battery life
    Junior Member tiki_attdroids's Avatar
    after 3 weeks, i finally "fixed" by battery issues
    i know ive heard it before, but i guess i was stupid for not thinking that ALL of the motoblur widgets were the issue, but thats exactly it. MOTOBLUR KILLS BATTERY LIFE! I deleted all motoblur widgets except for one, and this one (txt msg widget) was constantly using 3G all day long. After 3 weeks of using this phone and hating the battery life since i was only getting about 10 hours, i deleted that widget, the text message widget, from the desktop, and voila, battery doesnt drain at a constant rate anymore. Im currently at 97% after being unplugged for hours already. usually it drains 5% an hour, even when its not in use.
    Senior Member batmania15's Avatar
    MA
    Quote Originally Posted by tiki View Post
    That's quite interesting. I use that widget mainly for my email that gets displayed there to get a quick look at it without having to go through the inbox.
    Have you found a better widget to replace this for the email to get a quick look?
    I have 9 lockerz invites if interested PM me.
    Junior Member hooligan's Avatar
    That's odd. I have always used the Text Message widget, as well as the mail widget, and have great battery life. And I don't see the constant 3G usage either. Are you sure nothing else is actually running?
    no i havent found a better widget, unfortunately, you cant control any of the motoblur widgets to say how often they update. im just happy i found the culprit, and now my phone is normal (ie. i dont need to bring my charger to work).
    Junior Member peace's Avatar
    Los Angeles, CA
    I just purchased this handset yesterday at the AT&T store. The first thing I started noticing was that the battery life was less than satisfactory. Thanks for clearing this issue up tiki... my phone holds a decent charge now.
    lol. it's only a day old.
  1. HTC Desire HD Source Code Released
    Last Post: 10-25-2010, 12:55 PM
backflip battery life
backflip battery problems
battery for motorola backflip
battery life for motorola backflip
battery life of motorola backflip
does the motorola backflip has a good battery use
moto backflip battery life
moto backflip battery problems
motorola backflip bad battery life
motorola backflip battery
motorola backflip battery life
motorola backflip battery problems
motorola backflip review battery life
silverlight android
