Battery Usage
This is a discussion on Battery Usage within the Motorola Backflip forums, part of the Motorola Android Phones category; Is there a way to see the percentage of how much battery life you have left or have used? Aside from adding an app that ...
Results 1 to 10 of 10
Thread: Battery Usage
    Senior Member montREALady's Avatar
    Question Battery Usage
    Is there a way to see the percentage of how much battery life you have left or have used? Aside from adding an app that is. I've looked, but I may be missing it.
    Senior Member jmgib's Avatar
    Kentucky
    You can check in Settings -> Status -> About Phone
    There should be a line indicating whether the battery is charging or discharging as well as the current charge level.
    If the phone is charging, you can check the bottom of the "lock" screen and it will show the percentage of being fully charged. This goes away at full charge.
    You can use AnyCut to create a shortcut to the info that the phone reports.
    Directions here
    Quote Originally Posted by marvin View Post
    Directions here
    I wanted to know if I could do it without an app. Thx.
    Hey thanks!! Yes, I've noticed it when it's charging, I was more speaking about when it isn't. They recommend that you charge it when you have 25% left I believe.
    To view the battery status without any widgets:
    from a home screen:
    menu->Settings->About phone->Status
    The percentage of charge is the second item.
    FYI - your uptime since last boot is the last item on this list (scroll down to it)
    from a home screen:
    Thanks
    Moderator AndroidIsTheTruth_attdroids's Avatar
    Hook Em Texas
    Now I'm confused about this phone. I did a hard reset just because and now the battery seems to be much much more efficient. I haven't loaded my programs back on like Task and other stuff, but man the battery is running much more efficient. Weird.
    Junior Member waltah!'s Avatar
    The battery on mine has improved since I first purchased it. I think it just took some conditioning is all.
    Mine is horrendous, yesterday I took it off the charger right before I left the house at about 5 and by 11:30pm it was alerting me to charge it! I must have made one call and a few texts!
