Battery
This is a discussion on Battery within the Motorola Backflip forums, part of the Motorola Android Phones category; deleted by author...
Results 21 to 30 of 37
Thread: Battery
  1. #21
    deleted by author
  2. #22
    Senior Member NaplesBill's Avatar
    Quote Originally Posted by Lendal View Post
    Bill, if you can show somewhere that tests have been conducted by some scientific agency to show that an occasional discharge helps, then I'll accept it, gladly. And I'll thank you for the information.
    However, I've seen reports from several agencies now that indicate that's not the case for today's lithium ion batteries.
    In fact, at least one of them has said specifically that letting them discharge way down and then back up for 'conditioning' isn't especially good for the battery.
    I can't show you since I didn't record my own experiences but I can point you to XDA-Developers and you will find many threads regarding MSM-7200 based devices (like the Backflip) and battery issues with WM 6.5.3. Whether this is a software or hardware issue I do not know. But, I can verify 100% that the solutions on XDA-Developers worked for me on my Pure with WM 6.5.3.
  3. #23
    Junior Member waghalter's Avatar
    if amylyn1970 or any other user who purchased a battery from ebay would kindly post a link so that i might find a similar provider, that would be great. im interested in where you found your battery because it sounds much better than mine.
  4. #24
    Junior Member F_L_Abs's Avatar
    Honolulu, HI
    Quote Originally Posted by waghalter View Post
    Bump cause I'm also curious
  5. #25
    Member jdsatyr's Avatar
    did a simple search on ebay for battery for motorola backflip and got the following
    Motorola BN80 Battery BRAND NEW OEM Backflip (SNN5851A) - eBay (item 280499679657 end time May-28-10 17:40:00 PDT)
  6. #26
    Junior Member greekflip's Avatar
    ok after testing the google sync for the last week my batter life has doubled by disabling that feature. just a lil heads up.
  7. #27
    Android Lurker Jhon Smitch's Avatar
    Positives connected to each other and negative on the car be used to jump to chassis on the car getting jumped.
    next time try reading the directions
    option A is used to charge the battery, option B will cause BIG problems, i won't even touch option C..
  8. #28
    Junior Member gtwcs14's Avatar
    Quote Originally Posted by greekflip View Post
    good finding!
    also if you want to increase battery life just take a picture of something black! the less graphic intensive your display the longer duration without charging
  9. #29
    San Jose, CA
    So after a couple weeks with the phone, here's what I've noticed:
    Google Sync doesn't seem to have that much effect for me. I've had it on since day one and battery life has been just fine. However, I did try turning the My Location source on for a couple days (specifically the Use Wireless Networks option, I didn't even bother with GPS). This caused a VERY noticeable drop in battery life. It went back to normal as soon as I turned it off.
  10. #30
    Junior Member Eliza's Avatar
    I was wondering if someone could tell me how to change the battery on a Firex smoke detector? The smoke detectors seem to be wired to the house with a backup battery in case the power goes out.
    It's not as simple as just pulling out the old battery and popping in the new one. There's a plastic mold or case(with one red wire, one black wire, and one yellow wire) covering where the battery is held. So, basically I need to somehow remove this before I can get to the battery. Can anyone tell me the safe way to do this?
    I'm not trying to get electrocuted here Any help would be appreciated.
android 4.1.2 battery
android 4.1.2 battery killer
android 4.1.2 battery problem
android version 4.1.2 a battery hog
android version 4.1.2 battery life
droid dna completely charged when i went to bed.woke up to a dead phone
galaxy prevail kills fully charged battery in an hour
i took my battery out of my ampe a10 android to re-set it, does any one know if that will work?
i went to bed and i had just charged my galaxy iii and when i woke up the battery was dead?
if a motorola android,s battery is touched by metal what is the effect
the waze app is killing a fully charged battery
waze battery hog
