Battery
This is a discussion on Battery within the Motorola Backflip forums, part of the Motorola Android Phones category; Originally Posted by Eliza I was wondering if someone could tell me how to change the battery on a Firex smoke detector? The smoke detectors ...
Results 31 to 37 of 37
Thread: Battery
  1. #31
    Senior Member jmgib's Avatar
    Kentucky
    Quote Originally Posted by Eliza View Post
    I was wondering if someone could tell me how to change the battery on a Firex smoke detector? The smoke detectors seem to be wired to the house with a backup battery in case the power goes out.
    It's not as simple as just pulling out the old battery and popping in the new one. There's a plastic mold or case(with one red wire, one black wire, and one yellow wire) covering where the battery is held. So, basically I need to somehow remove this before I can get to the battery. Can anyone tell me the safe way to do this?
    I'm not trying to get electrocuted here Any help would be appreciated.
    You do realize you've posted this in a thread on a forum discussing cell phones, discussing the battery life for the Motorola Backflip phone?
  2. #32
    Junior Member dong2010's Avatar
    I agree with you the life of battery is running out quickly, i use a 3500mah backup battery and solar charger for my backflip.
  3. #33
    Quote Originally Posted by dong2010 View Post
    Have you bothered to apply the updates from AT&T? The greatly improve the batter live, and Preclair offers better battery life then an un-updated backflip.
  4. #34
    Senior Member Con5150's Avatar
    Bronx NY
    It's only been a few days but the battery life is so much better with the 2.1 upgrade....it's not even close.
  5. #35
    Junior Member timbuk2's Avatar
    Oklahoma City, OK
    Is it apparent that Wifi uses significant battery when your not connected to one? Would that be because it's always monitoring/searching for one?
    Thanks
  6. #36
    between 850-1900MHz
    71 times
    @Dorian_At_ATT
    Quote Originally Posted by timbuk2 View Post
    Thanks
    WiFi has a polling frequency... usually every 5-10 seconds it scans for new SSID's, even if you're connected to one currently. If you're not going to be using WiFi at the time, then yes, turning it off will save you some battery.
  7. #37
    Oklahoma City, OK
    Quote Originally Posted by quetzalcoatl View Post
    Have you conditioned your battery. It helps most of the time.
    I conditioned a couple of batteries for a friends non-smart phone (or whatever they are called) and now only get about half the battery life it seems. Perhaps I waited too long.
android 4.1.2 battery
android 4.1.2 battery killer
android 4.1.2 battery problem
android version 4.1.2 a battery hog
android version 4.1.2 battery life
droid dna completely charged when i went to bed.woke up to a dead phone
galaxy prevail kills fully charged battery in an hour
i took my battery out of my ampe a10 android to re-set it, does any one know if that will work?
i went to bed and i had just charged my galaxy iii and when i woke up the battery was dead?
if a motorola android,s battery is touched by metal what is the effect
the waze app is killing a fully charged battery
waze battery hog
