How to setup a different ring volume level
This is a discussion on How to setup a different ring volume level within the Motorola Backflip forums, part of the Motorola Android Phones category; My apologies if I have asked something already answered. I am not able to find any option(s) to setup different volume level (profiles) of the ...
Thread: How to setup a different ring volume level
    Junior Member Medo's Avatar
    Adelaide SA - Australia
    I am not able to find any option(s) to setup different volume level (profiles) of the ringing, as for during a meeting time or outdoor time and so on... My previous mobiles had that option (in build) and an easy shortcut to them. I need a help to find these options. Thank you.
    Well, I found how to resolve this issue by installing the ring toggle. It does the job but I would like also to assign different ring levels... but obviously you can’t have everything (at least at this stage).
    My apologies for the language mistakes. I doing my best (learning) and it will take some time (couple of years:mad until I will feel confident with my writing.
    Medo
    P.S. Can anyone point me for clear instructions how to install an application onto mobile but downloaded on the pc (windows). I can’t find application “the quick settings” using my mobile search (probably because is relatively new application) but can with PC, so only option is to install from my pc. Thank you.
    Senior Member jmgib's Avatar
    Kentucky
    Not sure why Quick Settings isn't showing up in the Market, but I checked (even tried scanning the QR code from Androlib).
    To install an .apk file you've downloaded to your PC, you should check the thread how to install apps not in marketplace.
    Thank you! I will give it a go....
    Medo
  1. Welcome to Android.net - Let us know what Android Phone you have!
    By danDroid in forum Introductions & Site Assistance
    Last Post: 01-26-2011, 09:47 PM
  2. Help: Tm G2 vs BB 9780
    Last Post: 10-30-2010, 03:58 PM
android skype low volume of ring
change skype ringtone android phone
how change ringer in skype android
how to change skype ringtone on android phone
how to change skypes ringtone on android phones
how to different ring android
how to increase ring volume on skype android
how to increase ringer volume skype android
how to increase volume in kindle during skype operation
increase ring volume on android skype
ringing volume skype android
skype android ring volume
skype low ringtone in android
skype ringer volume android
skype ringing volume on motorola mobile
