using motorola backflip without a dataplan?
This is a discussion on using motorola backflip without a dataplan? within the Motorola Backflip forums, part of the Motorola Android Phones category; i'm not sure how often this question has been asked before, but my friend sold me a motorola backflip phone for a relatively agreeable price. ...
Results 1 to 10 of 18
Thread: using motorola backflip without a dataplan?
    Junior Member tonyphamilyman's Avatar
    i'm not sure how often this question has been asked before, but my friend sold me a motorola backflip phone for a relatively agreeable price. however, i don't think i can afford a dataplan and want to use it solely as a phone with wifi. is that at all possible? i know you can do a similar thing with the iphone by reconfiguring the APN
    Senior Member jmgib's Avatar
    Kentucky
    Acutally this question has come up numerous times here already. The general suggestion is that it is a bad idea. Yes, it is possible to completely disable the cellular data on the phone, however ATT still may at their discretion add a dataplan once they recognize the Backflip on their network.
    So you can do this if you want, but it's basically like playing roulette.
    does at&t make it obvious when they add the data plan? e.g. sending you a letter, text, etc. ?
    Kentucky
    Usually you would receive a text I believe. Really though, you can't afford the new 200mb/mo data plan?
    Junior Member jordansals's Avatar
    las vegas
    Ya that doesn't sound like too good of an idea because the phone has live updates and feeds.. you wouldn't really get the the full experience? If that makes sense.
    how much does the new plan cost?
    also my friend apparently didn't have the charger. is the micro-usb port unique to the phone alone? none of my other micro-usb connectors fit into it
    Kentucky
    I don't believe the micro-usb plug itself is unique, but there have been claims that some usb cables will not charge the phones (seems Motorola used some customer wiring inside the cable).
    Junior Member oarsof6's Avatar
    Quote Originally Posted by tonyphamilyman View Post
    The 200mb/month plan is $15.00, and it's what I have. I am only using half of that, so it definitely meets my needs. The Backflip uses a micro USB cable, but I don't have experience using any cable other than the one that came with the phone.
    Member acmasters's Avatar
    I have used a number of other USB cables and haven't had any problems with them. I have had a lot of issues with the chargers themselves though (though you can always charge up from a computers USB port if you have too).
    I think you can also get chargers for the Backflip really cheap on Amazon and Ebay.
    Junior Member SPDworks's Avatar
    You don't want to have a smart phone for long without a data plan. It's entirely too simple to accidentally turn on the 'web' portion of the phone, and if you don't have a data plan in place, your carrier will charge you per bit of information, not for the length of time you're on the "web." As for the chargers available, there's loads of them via Amazon.com, along with nice gripp-y cool cases to protect the phone if you drop it, or whatever. What I'm wanting is a longer USB from the charger to the phone/USB port on my pc... I've never seen either a USB or even a Moto charger cable that's so short. It's annoying. Reminds me of the original dual shock controllers for PlayStation :P
  1. Hi, I am Jim, I am a Droid-A-Holic
    By JimMariner in forum Introductions & Site Assistance
    Last Post: 01-13-2011, 07:24 PM
  2. Dashboard Mount for Samsung Epic 4G
    Last Post: 08-04-2010, 05:48 PM
can i use an unlocked motorolla backflip without data
can i use the motorola backflip without a data plan ?
can you use the motorola mb300 backflip without a data plan
do i meed a data plan with motorola backflip
do you have to have a data plan with a motorola backflip
does the motorola backflip require a data plan
does the motorolla backflip require a data plan
how to turn off cellular data plan motorola backflip
motorola all cellular data backflip turn off
motorola backflip at&t without data plan
motorola backflip data plan required
motorola backflip what is using data
motorola backflip without data plan
using my motorola mb300 without data
will an unlocked backflip require a data plan
