Help! My Backflip won't send text messages!
This is a discussion on Help! My Backflip won't send text messages! within the Motorola Backflip forums, part of the Motorola Android Phones category; I can receive messages, but I can't send them. It started yesterday after I tried to send a relatively long message. I tried several times ...
Thread: Help! My Backflip won't send text messages!
    Junior Member cariann's Avatar
    I can receive messages, but I can't send them. It started yesterday after I tried to send a relatively long message. I tried several times to send it, but it would just come back with a red "x" on the message. I tried turning it off and turning it on, turning it off, taking the battery out and then turning it back on again. For awhile I was able to send messages, but then it just stopped all over again. Before this started, for the past week or so, when I would try to send a message it would give me a message telling me that I had to have a message recipient, when I did have a recipient.
    I don't know what else to do? I've searched the "help" feature on the phone, "troubleshooting" etc. Anybody? :mad:
    Senior Member Joe Coolcool's Avatar
    Check you're signal strength. Were you in a car while trying to do this? And do you think you went passed your text limit?
    Credit goes to ee0r.com for my avatar.
    Junior Member TineyTina's Avatar
    I have the exact problem. I got this phone probably in the middle of july. & this week it started. I have perfect signal I get 3G everywhere i live. Its not the signal at all. I restart my phone & sometimes that help. & sometimes if i forward the message it'll go through. Its really gettin rather annoying because its more frequent than ever.
    Junior Member IExpLoDEz's Avatar
    check your batter saver settings, as in the data timeout. that would stop me from getting texts even if i sent replys. if that isnt it, then check any apps. when i had automatic task killer on my phone would say it sent texts, and then i wouldnt get texts, id restart my phone and then it would resend texts and stuff
  1. YouTube?
    Last Post: 08-21-2010, 02:50 PM
backflip not send
backflip wont recieve texts
backflip wont send or recieve text messages
flip phone won't send texts
i cant send text on my motorola backflip
motorola android phone i can send texts but not receive them
motorola backflip messaging problems
motorola backflip not sending texts
motorola backflip will send but not receive text
motorola backflip won't send text
motorola backtlip wont get on enternet
motorola smart phone text messages wont send
my flip phone wont receive or send pictures
my motorola wont receive texts from a number
why wont my motorola android send text
