MotoBlur Widgets and Battery Drain
This is a discussion on MotoBlur Widgets and Battery Drain within the Motorola Backflip forums, part of the Motorola Android Phones category; Does anybody know if there's a connection with the MotoBlur widgets and horrible battery life? haha. I know if it does if you have it ...
Thread: MotoBlur Widgets and Battery Drain
    Junior Member JTSX99's Avatar
    Does anybody know if there's a connection with the MotoBlur widgets and horrible battery life? haha. I know if it does if you have it constantly updating all the time, but if I had no other widgets besides the Message widget, and it was just showing my text inbox, would that drain my battery?
    Senior Member jmgib's Avatar
    Kentucky
    The widget shouldn't affect battery life directly I wouldn't think. Your email is checked based on how often you set it to poll in the email settings.
com motorola.blur.home is pulling battery life
com.motorola.blur.home
com.motorola.blur.home battery
com.motorola.blur.home battery drain
com.motorola.blur.home battery usage
com.motorola.blur.home drainig battery
com.motorola.blur.home draining battery
motoblur battery
motoblur battery drains to fsst
motoblur battery life
motoblur draining battery
motoblur widget
motorola blur home battery drain
motorola blur home draining battery
motorola.blur.home
